Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 03-11-2009, 11:26 AM   #1
msieber109's Avatar
Profile:  1966 24' Tradewind
1975 29' Ambassador
Greenfield , Massachusetts
Tire size Question?
Is anybody running 235/80r16 tires on their AS?
If so, did you have any clearance problems?
Here's why... I am in the middle of purchasing a 1975 29' Ambassador and it needs tires. I have a pretty steep driveway and need all the ground clearance I can get. When my 1966 24' Tradewind was useable it had 225/75r15's on it and it was very close to dragging.
Thanks in advance
Mike
msieber109 is offline   Reply With Quote
Old 03-11-2009, 12:15 PM   #2
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
I am using 235X75x15's and I would not go any larger on the diameter.
The 80's would be 736mm in dia and the 75's would be 733mm's.
There are pics of my tires in my gallery here... http://www.airforums.com/photos/showimage.php?i=2586&catid=member&imageuser=682
Old 03-11-2009, 04:03 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
I am using 225 75 R 16.
If you say the current tires a dragging do you mean against the top of the wheel well box? If so I would check the axles before deciding on a tire. Sounds like the axles are weak.
If you go to a 16 in rim make sure the offset is correct to clear the inside of the wheel wells. My rims have a -8mm offset.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-11-2009, 09:15 PM   #4
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
The Ambassador is gonna have way more overhang than the Tradewind. So if the TW was barely making clearence the Ambassador with tall wheels and good axles may still not clear.
>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 03-11-2009, 09:36 PM   #5
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Here's an old trick they used to use on low slung custom cars. Mount a pair of heavy duty casters under the back bumper. Your trailer will roll smoothly onto your steep driveway with no dragging.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-11-2009, 09:37 PM   #6
msieber109's Avatar
1975 29' Ambassador
I Thank everyone for there input.
HowieE, how wide are your 16 inch rims?
And by dragging, I mean the rear bumper on the ground.
I am trying to get the tallest, narrowest tire I can for some added ground clearance and without damaging the AS.
Old 03-11-2009, 09:42 PM   #7
msieber109's Avatar
1975 29' Ambassador
I've been debating on doing something like this.
Old 03-12-2009, 05:41 AM   #8
Kristi Foster's Avatar
Profile:  Jonesboro , Georgia
Images: 36
Bumper Dragging on Steep Driveway
We can not get our newly purchased 68 Avion up our driveway for the same reason. Our elderly neighbor was kind enough to let us store it in his backyard until we could figure out a solution. He said he used to have leaf springs added to his mobile homes, years ago for extra lift. Our trailer doesn't have leaf springs though.He also mentioned skid plates and coasters. We are afraid of what all that weight placed on the bumper would do to the frame. It will be interesting to hear if the 16" tires solve the problem.
Kristi Foster is offline   Reply With Quote
Old 03-12-2009, 05:57 AM   #9
Profile:  , Minnesota
Images: 59
Airstream Registry
Sometimes you can fix a dragging problem by filling in the lowspots of your driveway, rather than adding casters to the bumper.
If you lay a couple of 2x8s in the lowest spot it may be all you need. This works especially well to bridge curbs and street gutters.
Old 03-12-2009, 06:10 AM   #10
Images: 36
We just brought home some bags of landscape stones to place in the road where it dips so low. They recently resurfaced our road and it does have very low shoulders for rain drainage.We plan to try the bags of stones this weekend.I will report back if it happens to work.
Old 03-12-2009, 11:04 AM   #11
Profile:  1977 31' Sovereign
McHenry , Illinois
I put some wheels on the frame rails to help. I also take the w/d bars off before I back in my uphill drive. I carry an extra deep drop ball and change to it, if required in unusual campsites. I keep to the .75 H ratio tires as well.
Old 03-13-2009, 09:39 AM   #12
msieber109's Avatar
1975 29' Ambassador
Boy, I'm not sure about filling in the low spots. My driveway is pretty smooth all the way to the road (gravel). I have already made arrangements with my neighbor to put it in her backyard if I can't get it up the driveway. But I don't want to leave it over there.
Thanks for all the imput.
Kristi Foster... please let me know how the landscape stones go.
Old 03-14-2009, 10:33 AM   #13
Profile:  2003 30' Classic
mount joy , Pennsylvania
This is my solution to my incline of driveway, the bumper would drag before I had put on the dolly wheels. If interested on mounting, I could post pics and directions on how I mounted my wheels. By mounting your wheels back on the bumper you lose clearance height, this is why I mounted mine where I did and as you can see they work.
ID:	76914   Click image for larger version
ID:	76916   Click image for larger version
krlajwvater is offline   Reply With Quote
Old 03-14-2009, 02:35 PM   #14
Images: 36
Please post more pictures and directions. Our driveway looks like yours!Thanks.
What is the right size tire? McLogger Tires 30 04-26-2009 08:23 PM
is this the tire size? zoeb nj Tires 2 05-11-2007 02:07 PM
20’ MH Tire size? Don B Airstream Motorhome Forums 7 09-29-2003 06:45 AM
Tire Size Question Creampuff Tires 12 05-16-2003 11:27 PM
tire size? goodgrey Tires 8 01-06-2003 08:27 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
