Old 03-14-2009, 04:19 PM   #15
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Greenfield , Massachusetts
Yes, please post pics and directions. Also if you could post the size of the "dolly wheels". Do those rotate or are they in a fixed position?
msieber109 is offline   Reply With Quote
Old 03-14-2009, 05:49 PM   #16
Road Ruler's Avatar
Images: 38
Originally Posted by krlajwvater View Post
This is my solution to my incline of driveway, the bumper would drag before I had put on the dolly wheels. If interested on mounting, I could post pics and directions on how I mounted my wheels. By mounting your wheels back on the bumper you lose clearance height, this is why I mounted mine where I did and as you can see they work.
Nice!!
Old 03-15-2009, 08:18 AM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by msieber109 View Post
HowieE, how wide are your 16 inch rims?
7in.
They are the 6th wheel down the right side of this page.
16" ALUMINUM TRAILER WHEELS FOR FIFTH WHEEL TRAVEL TRAILERS, TOWABLE RV'S, CARGO TRAILERS, HORSE TRAILERS, LIVESTOCK TRAILERS AND MORE
A 3960lbs. rated wheel.
2004 Excursion 4x4
Old 03-15-2009, 09:58 AM   #18
Originally Posted by Ganaraska View Post
Here's an old trick they used to use on low slung custom cars. Mount a pair of heavy duty casters under the back bumper. Your trailer will roll smoothly onto your steep driveway with no dragging.
Casters at the rear bumper will damage the rear quarter panels, the first time you use them.
Mounting wheels or casters forward on the frame forward of the last main bow, will "not" damage those quarter panels.
Old 03-15-2009, 01:12 PM   #19
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Thanks for the advice Andy.
So I understand that the way the krlajwvater has them installed should be okay.
krlajwvater...do you have any more pics of your setup?
Old 03-15-2009, 01:50 PM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It may be simpler to find a way to bridge the gutter. A lot of towns have really deep gutters, especially in the west. They do this to carry the water for gullywasher instead of putting in storm sewers. Maybe they will allow you to put in a steel grid as a bridge. That'll let water coming down your driveway to get into the gutter too. Or maybe, just do it, but check local ordinances to see what trouble you might get into.
Of course the casters are good for other such problems where the angle of departure is more than that of the trailer.
Gene
Old 03-15-2009, 02:35 PM   #21
richinny's Avatar
2011 34' Classic
maybe he could use one of these?
http://www.istockphoto.com/file_thum...e-and-moat.jpg
Ricky
Old 03-15-2009, 05:20 PM   #22
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Originally Posted by richinny View Post
As long as it doesn't turn out like this!!!
Old 03-15-2009, 05:35 PM   #23
Road Ruler's Avatar
Images: 38
Your new President is right. Time to beef up those bridges down south.
Old 03-15-2009, 06:14 PM   #24
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Mike,
may be they need a bigger caster wheel than 7" for that job.
>>>>>>>>>>Action
Old 03-15-2009, 06:31 PM   #25
Master of Universe
Gene's Avatar
Presto, historic covered bridge and coffee shop.
Gene
Old 03-15-2009, 06:34 PM   #26
richinny's Avatar
2011 34' Classic
oops, they put the garage on the wrong side of the house!
Ricky
Old 03-17-2009, 05:58 PM   #27
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
this is the way I mounted my dolly wheels.
1: this is the frame that I made up
2: the way I mounted 6" swivel dolly wheels
3: I drilled and tapped 4 -3/8" bolts into the frame on each side
4: to get the correct location of where I wanted them, I ran a
string under the rear tire to the lowest spot on the rear frame
5: dolly wheel in the back up position
6: dolly wheel in forward position
ID:	77081   Click image for larger version
ID:	77083   Click image for larger version
ID:	77085   Click image for larger version
krlajwvater is offline   Reply With Quote
Old 03-18-2009, 02:56 PM   #28
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
krlajwvater... thank you for posting the photos and directoins on how you installed those. I have yet to pick up my Ambassador so I'm not sure if I am going to need to do anything to it yet or not. If I do...that looks like the way to go.
Very nice job.
By the way...using that string was a great idea. I was wondering how you positioned them just right!!!
What is the right size tire? McLogger Tires 30 04-26-2009 08:23 PM
is this the tire size? zoeb nj Tires 2 05-11-2007 02:07 PM
20’ MH Tire size? Don B Airstream Motorhome Forums 7 09-29-2003 06:45 AM
Tire Size Question Creampuff Tires 12 05-16-2003 11:27 PM
tire size? goodgrey Tires 8 01-06-2003 08:27 PM
