Old 07-20-2015, 04:58 PM   #1
1964 26' Overlander
Cedar falls , Iowa
Tire size help 1964 overlander
Wonder if I would have any problems fitting michelin 235 75 15s on my 1964 Overlander. Need new tires before my upcoming trip, and with all the positive results with these tires I was thinking of jumping on board. Right now there are 700 15's on.
Bluemoon64 is offline   Reply With Quote
Old 07-20-2015, 05:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I had trouble getting 225's up into the wheelwells of our '63. If you have replaced the axles on yours, you may have better results.
Old 07-20-2015, 06:48 PM   #3
1964 26' Overlander
Cedar falls , Iowa
What would be my best choice for a tire? Stick with a ST possibly maxxis?
Old 07-20-2015, 06:57 PM   #4
Mission , Texas
My 75 Overlander also has 7x15 tires. They are 20 years old by the DOT date numbers, have no cracks, good tread with no signs of wear and hold air just fine. The axles have never been changed and the front edge of the wheel wells shows signs of tire contact and PO attempts to mitigate. Hmm...
7x15s are 27.88" in diameter.
225/75-15s are 28.1"
205/75-15s are 27.1"
Because the tires are antiques, they will be replaced as I move into the "make it road worthy" phase. The replacement tires will be 205/75-15s (poor abused wheel wells).
If I think I need more clearance after changing the tires, I'll opt for the 3" raise when replacing the axles.
nrgtrakr is offline   Reply With Quote
Old 07-20-2015, 07:06 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
It depends on how far the axle hub drops when you jack it up. If you have new axles, you can probably get them to fit. If you want a very similar tire to the 7.00x15 LT, Yokohama makes an RY 215 in 7R15. Very good tire.
You can also get get (I don't advocate their use, but they are the same size) the 7.00x15LT replacement tire as an ST205/90D15.
Good luck!
Lance
Top is offline   Reply With Quote
Old 07-20-2015, 08:08 PM   #6
1964 26' Overlander
Cedar falls , Iowa
Thank you all for your help. This tire search is driving me nuts! I haven't looked into the Yokos yet. I will check those out.
Old 07-20-2015, 08:19 PM   #7
1964 26' Overlander
Cedar falls , Iowa
How they sit right now on the ground I have about 1 3/4" to spare front and back
Old 07-20-2015, 10:29 PM   #8
Mission , Texas
In that case you might find this useful.
Tire Height Chart
Old 07-21-2015, 11:54 AM   #9
1967 26' Overlander
Spartanburg , South Carolina
I run Good Year Marathon ST225 75 R15's on my '67 Overlander. I would never run a tire that is not ST. Been using GYM's 15 years with no problems.
Jacob D is offline   Reply With Quote
Old 07-22-2015, 02:47 PM   #10
1964 26' Overlander
Cedar falls , Iowa
I decided to go with the Goodyear marathons 225 75r 15s. Getting them put on next Tuesday.
1964, 1964 overlander
Tire size for my '65 Overlander Frankiefiveo Tires 5 05-05-2012 04:13 PM
Tire size 1971 overlander rsqvet Tires 2 12-16-2010 12:45 PM
help with measurments from tire to tire '67 Caravel Trophycare General Repair Forum 0 07-19-2010 11:17 AM
Tire size for a '60 Overlander Scott S Tires 4 06-02-2008 07:09 AM
Tire size help please MatthewX Tires 3 04-20-2004 07:56 AM
