Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 01-24-2012, 07:32 AM   #1
Frankiefiveo's Avatar
1966 26' Overlander
Weeki Wachee , Florida
Tire size for my '65 Overlander
I have a 1965 airstream overlander 26' with double axle. This is my first travel trailer. Does anyone know what size tires they used back then and some recommendations for replacing the tires?
Frankiefiveo is offline   Reply With Quote
Old 01-24-2012, 09:06 AM   #2
Back then, the tire size was 700 X 15, load range "C".
Today that's changed to ST 225/75 R15, load range "C".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-24-2012, 11:03 AM   #3
1966 26' Overlander
Thanks Andy for the advice. Now I am a novice and I was looking up the tires you told me to look up and all of them are coming up with Load Range D instead of C. Is Load Range D better than C? I was looking at Goodyear Marathons.
Old 01-24-2012, 12:25 PM   #4
The "D" tires are usually used on heavier trailers, but you can use them, if you wish.
In order to soften the trailer ride, keep the tire pressure down to not more than 50 PSI, should you decide to use the "D" tires.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-04-2012, 05:31 PM   #5
1966 26' Overlander
Searsport , Maine
Hi, I have a similar problem, 1966, I believe Overlander, just started restoration. Currently has flats on split rims, where can I get the right size new rims? Thanks!!!!!
Athena is offline   Reply With Quote
Old 05-05-2012, 04:13 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Athena!
Welcome to the Forums and the world of Vintage Airstreams!
When the split rims were replaced on my '64 Overlander, the replacement wheels were standard black steel wheels having the following specifications:
  • 2,600 pounds load capacity
  • 15" x 6" with zero offset
  • 6 lugs on 5.5" center
  • 4.245" center bore
I believe that these same specifications apply to most Airstream and Argosy travel trailers from about 1960 to present. There are a variety of sources for new wheels including your local tire dealer, livestock trailer dealers, utility trailer dealers, RV dealers, as well as on-line retailers. I would suggest avoiding wheels from a salvage yard as the weight rating is an unknown as is the past history of the wheel . . . and in most cases the center bore is going to be too small to properly fit the Airstream.
Good luck with your coach!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Correct size wheel for '75 Overlander 27' Denbear Wheels, Hubs & Bearings 5 11-01-2011 03:27 PM
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
1974 Argosy 26' -- original rim / tire size austinringdi Tires 2 08-04-2011 05:28 AM
Translate tire size GeocamperAS Tires 1 04-10-2011 08:22 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
