Old 12-23-2006, 07:39 AM   #1
1960 24' Tradewind
NICEVILLE , Florida
Tire size and axle
I have just purchased a 1960 Tradewind. She was just sitting in the owners backyard for the past 15 years. The tires are flat and need replacing. Can I use the newer style tire size instead of the original 700x15 with out sacrificing safety and the possibility of the tire rubbing? The axel is the old style leaf spring. Do I need to replace it with the newer style or stick with the leaf spring one?
CAPEHORN31 is offline   Reply With Quote
Old 12-23-2006, 07:50 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Welcome to the FORUMS !!
Hello, This response it just my own personal opinion; Using the axle as is will be fine. You should check all mounting bolts and make sure there are no broken spring (leafs). Be sure to check the brakes and repack the bearings. I prefer to use the bias ply 7.00 x 15 tires. They are more readily available in most areas, lower in cost, give the trailer it's original ride height, and the tire is stiffer in the sidewall. Stiffer, makes for less sway, especially for the single axle trailer.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-23-2006, 09:38 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I'v only seen a few of the leaf spring models, don't recall if you have shocks. My one recomendation is to replace or add shocks for a leaf spring trailer. We're told we don't need them on the torsion axle models, but it seems we all maintain them, anyway.
Zep
Old 12-23-2006, 10:29 AM   #4
Images: 59
I think you should replace it with a new torsion style axle.
The original tire is 7.4" wide. If you replace it with a new metric ST tire the width is 8.8". I think you will have problems with the shock rubbing against the tire.
Old 12-23-2006, 03:08 PM   #5
1960 24' Tradewind
santa barbara , California
I own a 60 trdwnd and have the original hadco axle in it .I put in new brake
assemblies and replaced the springs (for my own satisfaction ) Sugarfoot
here on the forums also has a 60 trdwnd and just had her springs rearched .
Same tough hadco axle .no need to go with a torsion axle for any reason
that I can see if you have the original leaf spring unit in there .The hadco
axle is plenty strong .I run 700-15 Bias 9 ply tires .they look great due to
the heavy ribbed edges as original and they have a stiffer sidewall for better
stability ,the radials are softer ,ride smoother for sure ,but they cannot compare to the side wall strength of the bias .Mine have 4 plys in the side wall and 5 plys in the tread .All st tires have only 2 ply sidewalls .
most all bias tires will fit without rubbing the shocks ,fit the wheel well fine.
goodyear makes the workhorse rib ,towmaster offers bias (ive used them )
and I run herculese Bias now with great results .You do want new steel
2600# wheels with new tires (no split rims) all easily available .The shocks can be removed and matched up at your local napa or carquest stores .
they can go to the book with the specs of your old shocks and get you new ones .Alot of 60 trdwnd owners on the forums with the original hadco axles
in there trailers .The 59 units had smaller axles and smaller wheels and tires ,
so I also would upgrade to the 60 specs utilizing the heavier axle.The torsion
axle does offer a smoother ride so it is an alternative if you want to change out your whole axle .It does require axle mounting plates to be welded to your frame and alignment of the new axle to track straight plus shock relocation as well ,although the popular idea is too leave the shocks off the torsion axle but Airstream did not feel the same way and had installed them on all torsion axles up to present day ,now it appears some units today may or may not have shocks .they do serve a useful purpose to control tire rebound and do increase wheel control ,thats the point of having them .
Anyway ,for now just install the new wheels and tires and get her home
and decide what you might want to do .welcome to another 60 tradewind
owner .check with flyfshr here also ,hes got a registry going .what is the
bath configuration (ohio or ca built ) and the serial # .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 12-23-2006, 04:18 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I agree with Scott, there is no reason to try to re-engineer your suspension. Leaf suspension is fine, and if you decide to replace the axle and springs in-kind, total cost would be around $400.
Also, you can find 7.00Rx15 load range D tires for your trailer, they will give you the benefit of the radials, without losing ride height, or causing clearance problems in the wheelwells.
Old 12-23-2006, 05:32 PM   #7
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
And I agree with Scott and Terry. Yes, I had my springs re-arched and an extra leaf added last week. Gained 2" clearance which I needed because of new sewer fittings. The spring shop said the old Hadco axle and existing springs were in great shape, would be a waste of money to replace right now. The original setup for the 1960 TWs are less expensive to repair and have stood the test of time. First, get it home, check it out, then decide what works for you.
As far as a newer tire rubbing the shock because of increased cross-section width, this can happen. So measure carefully for clearance if you upgrade. A D class tire would give you more safety margin handling load. Congratulations to another 1960 Tradewind owner!
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 12-27-2006, 04:37 PM   #8
1960 24' Tradewind
NICEVILLE , Florida
Serial Number
The serial number to my Tradewind is 240261T. What does that number mean?
Old 12-27-2006, 05:24 PM   #9
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by CAPEHORN31
The serial number to my Tradewind is 240261T. What does that number mean? Thanks, Terry
Hi Terry:
Congratulations on your 1960 Tradewind. Its serial number means:
24 = length in feet
0 = last digit of 1960 model year
261 = production sequence number
T = twin bed floor plan
Best regards, and Happy New Year!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 12-27-2006, 05:40 PM   #10
1960 24' Tradewind
NICEVILLE , Florida
serial number 240261T. Built in Ohio. The bathroom seems smaller than the 22' Airstreams, Why?
Old 12-27-2006, 05:51 PM   #11
Well Preserved
1993 21' Sovereign
The Safari models had a more open floorplan, so the bathroom area would seem larger.
Terry.
No, not that Terry, the other one...
Old 12-27-2006, 06:49 PM   #12
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I run 7.00-15 on my 31'. Love them. I trust them more than GY Marathons.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-27-2006, 07:04 PM   #13
Images: 59
Does anyone use Goodyear 8.75R16.5LT E tires? I am considering them for my single axle Tradewind and would appreciate any comments.
Old 12-27-2006, 10:01 PM   #14
1963 30' Sovereign
sedalia , Missouri
I have four H78-15L -8ply with rims came off 66 sovereign,also set of axles
seem to be in good shape,if interested email .lchancellor@charter.net
thanks joinmo
JOINMO is offline   Reply With Quote
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
63 flyingcloud tire n rim size 63streamer Tires 1 06-19-2006 10:56 PM
Tire Size Question Creampuff Tires 12 05-16-2003 11:27 PM
tire size? goodgrey Tires 8 01-06-2003 08:27 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
