Old 06-03-2012, 03:05 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Tire rim
Can some one please tell me if the aluminum hub located on the tire rim is supposed to come off when the tire is taken off the trailer. I had a flat tire and when it was taken off the hub came loose. I want to put the original tire back on but am concern that the hub might rattle if it is not spot welded.
John
urnmor is offline   Reply With Quote
Old 06-03-2012, 03:19 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I am guessing you are talking about the shiny round thing that is inserted into the center of the wheel. Yes, it will fall out and then you put it back, bolt on the wheel and forget about it.
Hub can mean lots of different parts and sometimes the brake drum is called a hub. I think of the shiny round thing as a hub cap.
Gene
Old 06-03-2012, 03:21 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
If you've ever been in the working end of a tire shop, you may have seen that the tire changing and wheel balancing equipment has a post that extends through the hole in the center of the wheel. The cap on many presses in from the backside of the wheel and is held I place by the hub when the wheel is mounted. They are usually snug when everything is bolted down.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 06-03-2012, 04:54 PM   #4
urnmor's Avatar
Berlin , Maryland
My thanks to both of you. I now can put the original tire back on the AS and not worry about the hub cap rattling
John
Old 06-03-2012, 06:08 PM   #5
"Cloudsplitter"
Thumbs up
John
If it's like our wheels theres an O-ring at fits over the cap onto a flange at the base to stop that rattling.
Name:	AS STUFF 012.jpg
Old 06-03-2012, 06:12 PM   #6
Master of Universe
Gene's Avatar
Ours does not have an O-ring. Don't worry that you lost it John.
Gene
Old 06-03-2012, 07:28 PM   #7
urnmor's Avatar
Berlin , Maryland
Gene
I will have to look to see if it has one
John
Old 10-08-2012, 10:45 AM   #8
1971 29' Ambassador
guyton , Georgia
bolt pattern for 1971 as 29 ft ambassador looking for chrome steel?
r.swanson is offline   Reply With Quote
