Old 05-08-2013, 02:31 PM   #1
2003 25' Safari
:iyy;e Torch Key , Florida
tire replacment
I plan to replace tires with Load Rating "D" which is 2540 ibs with 65 psi. My 25' Safari has a GVWR of 6300 lbs. The Load Rating "C" which is 2150 lbs at 50 psi or 8600 lbs total should handle my trailer. Tires are ST225x75x15. I prefer the 50 psi. I have read most of the posts on tires but not much on changing load rating. Thanks for your help.
Capt Jeff is offline   Reply With Quote
Old 05-08-2013, 03:09 PM   #2
SteveH's Avatar
Common Sense , Texas
Going from a "C" at 50 psi and 2150 lb rating to a "D" at the same 50 psi will gain you noting in load capacity, and you can check that on the charts if you want.
You will only gain load capacity with the D's when you go to higher air pressure.
Regards,
Steve
Old 05-08-2013, 03:15 PM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I think (bad idea! ) he wants to do the opposite, go from the 65psi "D" to the "C" 50 psi. JMHO
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-09-2013, 06:06 AM   #4
CapriRacer
CapriRacer's Avatar
I'm in the , US
This sounds like a terribly idea.
One of the principals in engineering is to "under-utilize" - that is, specify a larger component than is needed in order to reduce the risk of failure. Of course, the larger the component, the less risk.
We all know about the issues with ST tires and going larger seems to be one of the fixes to the issue. You're trying to go the opposite direction - and we know that is the wrong way.
CapriRacer is offline   Reply With Quote
Old 05-09-2013, 08:19 PM   #5
BlackAces's Avatar
Taylors , South Carolina
Are you replacing Original Equipment tires as depicted on the trailer's certification label? If so the reference is applicable.
I can post numerous references on this load capacity subject. The one referenced below gets right to the point.
http://us.coopertire.com/Tire-Safety/Replacement-Tire-Guide/Load-Capacity.aspx
That information is from a combination of government regulations and tire industry standards.
BlackAces
USN - RET - PDRL
DoD & SSA - RET
BlackAces is offline   Reply With Quote
Old 05-09-2013, 10:26 PM   #6
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
I bought a tri-axle 34 ft Airstream that had just been re-shod with 10 ply rating 80 psi tires. It took me a little while to realize that the tires were my main problem. I lowered the air pressure to 60 and the tire shoulders began to wear excessively. I changed to Michelin 235/75x15. The load rating is right. The recommended air pressure is 50psi, which is what my trailer specs call for. The ride of the trailer is 100% better with these softer, less inflated tires There is no way that I would change back.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
