Old 10-14-2011, 06:41 AM   #29
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Skatiero,
I have the same trailer you have (1989 Excella). I am on my second year towing with Carlisle radial tires LRD and work well for the traveling we do (trips have been typically 100 - 500 miles/day). No complaints. They don't loose air, don't seem to be any hotter than the tow vehicle tires on the highway and I often run 70 mph. The tires are kept at 60 psi.
These were at least $40 cheaper per tire than any Good Year Marathon and $20 cheaper than closest ST tire competitor.
I have no doubts that LT tires and those going to 16" tires have a better setup but that can be pricey.
I have probably jinxed myself and will have a blowout on the next trip.
Good Luck and don't over think this
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-14-2011, 07:56 AM   #30
rideair's Avatar
One of the main diff's between "trailer" and "LT" is the "speed rating". Most if not all "trailer" tires are rated at 65mph compared to the "LT" that could have a speed rating of 90mph or more.
If one looks at many of the old trailer tires that were put on on the rigs back in the 60's, 70's you will find it's the same exact tire you can still find today. The only difference is the name on the side, Power King, Road King, USA Trail, etc.... the tread and side wall pattern is still the same using what appears to be the same mold.
Paul Waddell
rideair is offline   Reply With Quote
Old 10-14-2011, 04:19 PM   #31
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Originally Posted by crispyboy View Post
Skatiero,
We have a 27 ft 1984 Sovereign. Put Carlisle ST225/75R15E's on it. Max pressure on the side says 80psi. And the Carlisle site and Discount tire will both will you to run it at the max. Now I can tell you that at 80 psi I could bounce that trailer to pieces. So we moved down to 72 psi and all seems well. Only about 2500 miles and 5 months or so on the tires.
But I simply don't know if I am running a risk by going lower than the recommended pressures. So...what to do, what to do...
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 10-14-2011, 06:20 PM   #32
Baltimore , Maryland
Originally Posted by rideair View Post
if one looks at many of the old trailer tires that were put on on the rigs back in the 60's, 70's you will find it's the same exact tire you can still find today. The only difference is the name on the side, power king, road king, usa trail, etc.... The tread and side wall pattern is still the same using what appears to be the same mold.
Old 10-14-2011, 07:46 PM   #33
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Michelin LTX 235/75R15 Load Range C
18,000 miles so far. Still have 12/32nd" depth. Love 'em.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 10-14-2011, 08:16 PM   #34
casa3805's Avatar
Images: 41
Rluhr, Are these on the Carvel or the Safari?
Chuck & Skye
WBCCI 3805
Old 10-15-2011, 05:12 AM   #35
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Chuck,
IMO...72psi in an E rated tire is fine for your rig.(nowhere near max load). Our TV's LTX Michelin's are also E and 80 max pressure, I run them at 72F, 74R, 45k without any problems.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 10-15-2011, 06:14 AM   #36
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
These are on his Safari. You can read about all of Rich's tire issues on his blog here. His experience with these tires is a big part of why I chose them.
Lance
Top is offline   Reply With Quote
Old 10-15-2011, 03:39 PM   #37
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Glad my experience was helpful to you, Lance!
I think a better link would be this one: Man In The Maze » Blog Archive » Running gear maintenance day <--- directly to my most recent blog entry on the subject.
For the full, gory, tale of our years of tire challenges and why we ended up with Michelins, check both of the blogs linked below in my signature and do a search on the term "tires."
Short version: we tried every brand of "ST" tire we could find and they all failed prematurely, until we switched to Michelin light truck tires.
YMMV. Our lightweight 1968 Caravel can run just about any tire without a problem. There's a big difference between a 17-foot, 2500 lb trailer and a 30-foot, tandem-axle 7500 lb trailer. So I don't recommend that people go to the trouble of switching unless they are having issues such as premature wear, belt separation, or short tire life.
Old 10-19-2011, 02:30 PM   #38
1986 32' Excella
Dover , Delaware
Also needing help
I'm also in need of tires & have some other questions. Have '86 Excella 32'. Returned from trip last weekend & knew before going south in Jan/Feb would need tires. Whoa!! While checking I found the rf tire had some terrible wear, primarily on inside including cupping down to metal belt. I'm thinking either really bad balance or a brake hanging up. No evidence of problem on the rb tire nor on left. Also considering aluminum wheels at same time( I've always had problem with wheel cover on one wheel spinning & pulling on the stem.) Thought I might just get away from wheel cover. Should I replace shocks at same time? Have additional questions if anyone has chance to advise me. Thanks.
RB
rbhinzman is offline   Reply With Quote
Old 10-19-2011, 03:04 PM   #39
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I have had great luck with bias tires. I also fear the damage a steel belt will do to a fenderwell.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 10-21-2011, 04:21 PM   #40
RB
RB,
If the cupping is primarily in one area of the tire,(heavy spot), it's most likely a balance problem. Worn shocks will exacerbate the problem...tire bounce.
Centramatic balancers and new shocks may be in order....along with some new shoes.
RLC
RLC
"Tahawus"
Old 10-25-2011, 02:22 PM   #41
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Boondocker View Post
So am I correct in thinking that the trend is toward light truck tires?
I try to keep up with this on various boards. I'm in favor of LT tires as a result. The second portion of that is to stay with correct load range, overall, so as to keep tire pressures at or near to sidewall maximums to keep op-temps low and sidewall stiffness high. Generally. This is my "reading" of consensus, that LT is increasingly favored, especially on heavier trailers.
Some of this info is gleaned from commercial operators who take their equipment through situations that RV'ers avoid (well, most of them). I do know that ST tires are no longer acceptable to me.
The last set we had were the YOKOHAMA RY-215s in 7.00x15 on our Silver Streak. At maximum psi (correct load rating for us; an 8k GVWR trailer; we were at .92) the temps stayed lower than on the Michelins on the truck in 105F Texas heat at 63-mph.
I'm thinking M&S Michelins for the next one. Much depends on whether tandem or tridem.
Centramatics and new shock absorbers were also done.
Old 10-28-2011, 07:32 PM   #42
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Correct me if I am wrong, but the best ply rating on the 15" LT's is a "C" rated or 6 ply. Not saying that I won't switch the next time I need new AS rubber, but I am wondering about the toughness I will loose from a 10 ply to a 6 ply.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Spare Tire Cover Replacement Rv-Voyager Classic Motorhomes 15 02-16-2018 08:08 AM
Full time in the Florida Keys. cjf111 Full-Timing 13 07-27-2011 02:48 PM
Replacement tires for 2006 Safari 23 Goal15 Tires 0 05-16-2011 12:45 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
