Old 06-08-2015, 09:30 AM   #1
2007 23' Safari SE
MURDOCK , Florida
Tire replacement
We own a 2007 23' Safari travel trailer. It's time for tire replacement. I just noticed that the Greenball Towmaster trailer tires that I purchased 30 months ago from Costco are showing severe wear with steel belts visible on one of the tires and serious tread wear on all tires. I would like to know what tires are considered best and where they are available. These tires have over 22000 miles. Magoo
magoo is offline   Reply With Quote
Old 06-08-2015, 10:16 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Most people I know are switching to a brand name of light truck tire (LT) with Michelin being the most common and ditching the trailer tires. If you have 15 or 16 inch wheels that is relatively easy as there are lots of choices. If you have 14 inch wheels your choices will be limited but I believe that you will still find a couple of choices.
Light truck tires are available everywhere, even Costco. Just make sure they know how to raise the trailer to do the install.
Bob Martel
WBCCI# 5766
Old 06-09-2015, 04:27 AM   #3
CapriRacer
CapriRacer's Avatar
I'm in the , US
First, trailer tires don't get appreciable wear unless there is an alignment problem - and it sounds like you have one. So check that out first.
Second, the problem with trailer tires is multi-leveled.
1) Some trailer manufacturers underestimate the actual load on the tires.
2) Some trailer manufacturers select tires that are marginal for load carrying capacity.
3) Some trailer owners don't follow the speed restrictions.
4) Some trailer tire manufacturers don't produced high quality tires.
These combinations of things cause quite a bit of a kerfuddle within the RV community - and many folks have staked out territory as to what to do about it. Do a search to see the threads where this is discussed.
Plus look below and you'll see others chime in with their particular line of thought. Since I have the floor, I'll start.
First, weight the trailer - fully loaded and tire by tire if you can. If you can't weigh each tire individually, you will need to account for side to side and front to rear load variation. Then adjust the loads for the speeds you tow at. I recommend selecting tires such that they are loaded to no more than 85% of their rated capacity.
CapriRacer is offline   Reply With Quote
Airstream Tire Poll for Travel Trailers with NO Tire Failures Phoenix Tires 5 01-09-2015 08:11 AM
Blown tire-Discount Tire sold me Carlisle?? FLYNCLD Tires 15 08-22-2010 09:45 AM
help with measurments from tire to tire '67 Caravel Trophycare General Repair Forum 0 07-19-2010 11:17 AM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
