Old 03-15-2013, 02:44 PM   #15
Vblgrl9's Avatar
1978 31' Sovereign
Raleigh , North Carolina
I'm positive they are that size
Vblgrl9 is offline   Reply With Quote
Old 03-15-2013, 04:14 PM   #16
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Vblgrl9 View Post
Even if my trailer weight is 4800 lbs?
If you didn't weigh the trailer yourself and are going by the Airstream listed weight I hate to break it to you but that is the dry weight without options.
So unless your trailer is gutted you probably need to add the weight of A/C, fridge, propane, anything else that was optional and anything you put in the trailer. For many years if there was a choice of two options that you couldn't get an RV without one of them no weight for either item was counted into the base weight. So unless your trailer has less in it then stock I doubt you are under 6500lbs ready to camp with empty tanks. I weighed a 73 Sovereign 31' that supposedly weighed 5005lbs it weighed 6700lbs with cooking stuff, 4 chairs, clothing for 2 for 2 weeks, hoses, adapters, some leveling blocks, empty fridge and empty tanks.
"Dry weight without options" is a mythical number unethical or incompetent dealers use to con people into buying a trailer their tow vehicle isn't rated to tow. Mythical because almost all travel trailers weighed more then that when they left the factory years ago.
Old 03-15-2013, 04:34 PM   #17
1976 Argosy 22
Ventura , California
You're absolutely sure that you're not mistaking them for Michelin Latitude Tour P225/75/R16 tires with a load rating of 1804lbs?
elmer is offline   Reply With Quote
Old 03-15-2013, 08:46 PM   #18
1973 31' Excella 500
Marysville , Washington
The AS has a placard with the Gross Weight on it. That would be a good guide.
Not Done is offline   Reply With Quote
