Old 03-08-2012, 03:42 PM   #1
2007 27' Safari FB SE
Ft Wright , Kentucky
Tire Recommendation 2006 25' Safari
Looking for recommendations on tires to replace the original set of Goodyear Marathons. Do not wish to change original cast wheels.
jhohe is offline   Reply With Quote
Old 03-08-2012, 04:51 PM   #2
r carl's Avatar
Lin , Ne
Continental*Vanco 2
Old 03-08-2012, 05:43 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The topic is controversial.
I believe your trailer originally came with 225/75R15 load range C tires. I would suggest replacing those with Goodyear Marathons in the same size but with load range D, so that you can run them at somewhat higher pressures, and reduce the heat buildup that contributes to tire failures.
The Continental Vanco that R Carl suggests would also be a good choice.
The other tires in load range D in similar sizes are not from major manufacturers, and I would avoid them.
Old 03-08-2012, 05:49 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"The topic is controversial."
New, round, balanced, D load, light truck with Centramatic's,
See that wasn't so bad.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Lady - A 1969 23' Safari; Update and fixes BoCox 1969 - 1973 Safari 28 08-25-2013 09:00 PM
Centramatics reduce tire failures? boondockdad Tires 35 03-11-2012 09:08 AM
Help towing an Airstream Safari from AZ to CA drmittens On The Road... 4 03-08-2012 11:45 PM
2006, AIRSTREAM INTERNATIONAL , 28 CCD ,75th ANNIVERSARY EDITION eBay Watch Airstreams on eBay 0 03-08-2012 02:20 PM
Front mounted spare tire ideas? dryenko Wheels, Hubs & Bearings 6 03-08-2012 02:00 PM
