Old 09-08-2003, 12:06 PM   #1
1990 32' Excella
jonesboro , Arkansas
Cool Tire recalls
I just purchased a 86 31' sovereign with goodyear tires . I was told that there had been a recall on some of them. I was met with a blank stare at my local dealer. Does any one know how or where to get info on recalls. Thanks
joel is offline   Reply With Quote
Old 09-08-2003, 12:32 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Check with the Consumer Product Safety Commissions Web site. Obviously you will need to identify your tires and the date of production (stamped on the sidewall) to find out if there are recalls.
Here is the link to the site. http://www.cpsc.gov/cpscpub/prerel/prerel.html
Good luck in your search.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-09-2003, 11:06 AM   #3
1990 32' Excella
Cool recall
Thanks . I did not find anything on a recall yet ,but I am going to check with a dealer out of Memphis, it is only an hour from where I live.
Old 09-09-2003, 12:36 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
The tires in question were the Goodyear Marathon ST225/75R-15 load range D that were made in the mid to late 1990's. According to Goodyear, there never was a recall on the tires. You can call them at their 800 number and get the "claims dept" for further details. The replacement tires now have a circled "s" after the word "Marathon" on the sidewall.
Dwight is offline   Reply With Quote
Old 09-09-2003, 07:10 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Joel,
I think you will find that Goodyear has not had a "recall".
The 5th wheel trailer industry is making these behemoths you see on the road and they spec a tire that is small due to trailer height concerns and also they don't want to pay for a steel/steel radial truck tire with 80psi inflation. Also, everyone is towing with turbo diesels at 75 miles per hour. The end result is that there have been a number of tire failures on original equipment tires. I think you will find that Goodyear has been making sales concessions to people with relatively new trailers that have experienced tire failures.
I have been told that Goodyear put a nylon overlay belt into the construction about 2 years ago which would make the new construction more desireable than the old but, if your tire is the ST225/75r15 LRD and you keep it inflated to the 65psi, you should not have a problem.
My trailer is a 1987 with tires that are nearly two years old. I will start watching them close for sidewall cracking as they approach 7 years old. My 29' loaded is at about 75% of the sidewall max load rating and I would think your 31' is about the same.
wingfoot321 is offline   Reply With Quote
Old 09-09-2003, 10:16 PM   #6
1990 32' Excella
Cool recall
Thanks everybody,goes to show you "the more mids the better ". My tires are less than 2 years old so I won't worry and will just check them carefully as allways.
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
