Old 08-03-2016, 09:50 AM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Tire question...AGAIN!
I realize that this topic has been discussed in numerous threads, but I don't have time to weed through them all.
So, any recommendations on a good tire for my '02 19' Bambi? The Michelin LTXP235/75R15XL gets mentioned here a lot, but will they handle the load well?
FWIW, I don't load the trailer with much extra weight.
AIR #2753
rfield54 is offline   Reply With Quote
Old 08-03-2016, 10:40 AM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . we had good luck / excellent service from Carlilse STR from Discount Tire on 2 trailers..........regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-03-2016, 10:43 AM   #3
Long Island , New York
Here is the list of threads in the Tires sub-forum FWIW:
The best bet is to use a reputable tire dealer IMO, especially as the load and speed ratings are difficult to research online from the Michelin site, and the company seems to be changing its entire line-up all the time.
Good luck!
PS -- what size tires do you have now?
Old 08-03-2016, 12:03 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The LTX Michelin in that size is rated for 1983 lbs for trailer use. You have to look at your axle rating and get tires that meet or exceed the axle rating stamped on the trailer axle loading tag. At least in TN that is a D. O. T. requirement. Do note that the groxx axle load is lower than the GVWR.
The newer Michelin Defender in that size carries just slightly more weight but I do not know how much.
I have only used the LTX on a 2 axle trailer and have no knowledge of single axle trailers.
Old 08-11-2016, 12:09 PM   #5
2005 19' Safari
The per-tire load of the 235/75x15 "XL" passenger car tire is too low for a 19' single axle Bambi. You MUST use a 15-inch, load range D or E (D=65 psi max, E=80 psi max), ST (special trailer) tire or switch to 16-inch, load range E, LT (light truck) tire.
Specs say your 19' Bambi probably weighs around 4,500 pounds, so per-tire load is 2,250. 235/75x15 XL tire's derated max load is 1,985 pounds.
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 11:15 AM
Grievance time again -Leo gets slammed again LI Pets WBCCI Forum 47 12-23-2009 01:02 AM
Murphy's Law Strikes Again and Again . . . . . . overlander64 Our Community 5 04-21-2003 11:53 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
