Old 06-10-2010, 07:43 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
tire question
Went with a straight Dexter axle, 6 bolts, for my 55 Safari, which raised the trailer about 3" and I'm not liking the look. I have no problem going back to a drop axle. but is it possible to go with a low profile tire to bring it down a little. The tires that are on it are 225 75/D15 and I'm going with new anyway.
toastie is offline   Reply With Quote
Old 06-10-2010, 11:15 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
No on low profile
I would think that low profile tires would be really hard on your trailer. Very little sidewall to provide some cushion. AS are really sensitive to hard rides.
Old 06-10-2010, 11:54 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
You can also have the springs recurved if there's room underneath; this can take some of the arc out of the leaf springs and lower the ride height.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-11-2010, 12:00 AM   #4
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I don't think you will find too many choices. Your current tire is the 225/75R15 which means it is a 75 profile or 75% as tall (bead to tread) as it is wide.
You can look through various tire manufacturers and try to find a lower profile such as 70 or 65.
You can go with a smaller tire such as the 205/75R15 which my rough calculation says it is approx 1.2" smaller on diameter or .6" on radius which would be axle centerline to ground.
You could consider 14" rims.
wingfoot321 is offline   Reply With Quote
Tire Question? gaylejoe On The Road... 9 12-16-2009 05:06 AM
spare tire question millvalleyca Tires 42 08-22-2007 11:05 AM
'71 Sovereign Tire Question libmeister53 Tires 5 08-21-2007 11:00 AM
Tire Question Uncle Jack Tires 2 06-22-2007 04:42 PM
Tire question ???? RichardT Airstream Motorhome Forums 1 01-31-2005 08:33 PM
