Old 09-25-2016, 08:55 AM   #1
2007 16' Bambi
Owen Sound , Ontario
Tire Psi
Hi....I have a 16' Bambi and have 16" wheels. It says on the tire the psi is 65. What psi should I actually fill the tire to while cold?
Butch
Butch McNabb is offline   Reply With Quote
Old 09-25-2016, 09:07 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Refer to the manufacture inflation chart. The printed number on the tire side wall is a Max. pressure. The pressure you want is a function to the weight of the trailer as loaded.
2004 Excursion 4x4
Old 09-25-2016, 08:50 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Or, you can read commentary on this subject from the two tire engineers who post here that the pressure tables don't apply to tires in trailer service. Max pressure per sidewall statement is best for longest and most reliable tire service. Do otherwise at a greater risk of tire failure.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 10-07-2016, 06:30 PM   #4
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
Put at 65 psi when cold. Preferably in the morning. It is difficult to keep it at that depending on time of year and day. I would venture to say that all these variable are taken into consideration when the tire is being developed. Just look at the pro drivers. Once a tire is on the pressure is the last they are thinking about. And please don't put LT tires on a travel trailer. They are constructed differently and they flex. Plus the load an LT tire can handle is less than a tire for trailers.
Barbieri is offline   Reply With Quote
Old 10-07-2016, 06:37 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I run my ST tires at the max printed on the sidewall.
CRH is offline   Reply With Quote
Old 10-08-2016, 07:37 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
30K miles on ST tires at 55psi. Never had a problem. No rivets shearing or hard ride problem. I limit my speed to 60mph.
Old 10-19-2016, 11:55 AM   #7
2016 19ft flying cloud
Spokane , Washington
Tire pressure value indicators
Anyone have any luck with the screw on tire pressure indicators set at 65psi?
Seems like a good idea if you don't have a TPMS on board
Spinonedad is offline   Reply With Quote
Old 10-19-2016, 06:52 PM   #8
2016 25' Flying Cloud
Gettysburg , Pennsylvania
I run mine between 65 and 68 psi.
majorairhead is offline   Reply With Quote
Old 10-24-2016, 08:05 PM   #9
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
I can almost bet that the engineers that developed the tires had constructed a product that can handle the gyrations of tp. Just as long as you don't run them like run flat tires. Did you know that the tp of tires facing the sun in the morning is higher that the tp of tires in the shade.
Old 10-24-2016, 09:03 PM   #10
HowieE's Avatar
Images: 12
You might open a Physics book and look up TPV
2004 Excursion 4x4
Old 10-25-2016, 05:06 AM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As you have found there is a max cold fill pressure on the side wall of the tire. The vehicle manufacturer (a travel trailer in this case) will also publish a cold fill pressure as well based on the design of the vehicle.
Vehicle manufacturers tend to install a tire that will just accomodate the max load with not much margin. Most passenger vehicles rarely see the max load. Many travel trailer run at or near the max load all the time, so inflating the tires to max pressure (on a cold tire) shown on the tire side wall will handle that load.
Weighing your trailer will help you to understand what load is being applied to the tires. It is useful to know that load on each tire. Or at least from side to side, front to back.
Always fill a cold tire. As a tire is used the pressure will rise because the tire is flexing in use and generates friction which generates heat. And heat causes the presure to increase. And check tires and tire pressure frequently.
>>>>>>>>>>>Action
Old 10-25-2016, 05:34 AM   #12
Gainesville , Florida
Your comments about LT tires are misleading. Your opinion based on misinterpreting facts.
Old 12-06-2016, 10:35 PM   #13
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
Sorry but it is not an opinion. I just read what is on a tire and what the manufacturer has posted on the internet.
Old 12-06-2016, 11:00 PM   #14
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Here is a very long thread that I have saved and started to read. PSI discussion starts on page 7 or so I believe,
http://www.airforums.com/forums/f465...s-69297-8.html
Simply a coincidence that it opens up to Action (Moderator Dude post # 11 above) as that is where I left off. This is a great thread with a lot of varied info re tires, inflation, LT's vs ST's, 15's >16's. Also like hitches, TV's etc, no shortage of threads on the tire and tire/subcategory subject
CruizinDux is offline   Reply With Quote
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
What PSI should I have my tires? silversled Tires 7 03-03-2008 12:05 AM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
