Old 09-15-2013, 07:30 AM   #1
safari25-05's Avatar
summerfield , Florida
tire protection from asphalt tarmac
I live in Fl and I store my trailer in a black top covered asphalt rv storage lot. I have seen some guys in the past put boards under their tires and never had a chance to ask why? I've now noticed my yr old tires have fine hairline cracks in the sidewall rubber already. I have ordered covers for storage against the UV rays, however I was wondering if a board under the tires would also help to insulate against the heat transfer from the tarmac? Any input would be appreciated.... Thanks
safari25-05 is offline   Reply With Quote
Old 09-15-2013, 07:39 AM   #2
1994 30' Excella
Mississauga , Ontario
It might help with heat somewhat. I think the bigger issue is how long it sits between use. If you use it regularly then it will not sit on the same part of the tire each time. I easily get 5 to 7 years out of tires and replace due to age not tread wear. Also I have never parked on boards or covered them to block the sun. In fact the tires on one side see very little sun where I park and I haven't noticed any difference side to side.
Al
Al and Jean
TAC ON-3
Old 09-15-2013, 09:01 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I don't see water as being helpful either...
......First time I moved the trailer after an extended period I had a green patch on the concrete.
I cover and use a "drain tile" to allow the tread contact patch to dry out.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-15-2013, 03:55 PM   #4
1988 32' Excella
Robbinsville , New Jersey
my yr old tires
Does this mean 1 year old or did you miss putting in a number?
Old 09-16-2013, 06:51 AM   #5
I meant..
I did mean 1 yr old....
