Old 11-12-2006, 08:34 PM   #1
2007 25' Safari FB SE
Lake Forest , Illinois
Tire Presuure and inflation
I am new at this and I am on the road. Every morning I take the cold pressure reading of my tires, and make notes re: the number of pounds that are required. When I hit the first fuel station I stop and attemp to put in air. It is a horrible job attempting to reach the short valves and attach the air hose.Finally today I paid a boy at Flying J who had to fix the air hose before filling. He also stuggled. Any suggestions?
woodedareas is offline   Reply With Quote
Old 11-12-2006, 08:41 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Buy a set of valve stem extensions. They screw on the valve stem, and protrude through the hubcap. Available in various lengths.
Old 11-12-2006, 08:54 PM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
Tire Pressure and Inflation
Better yet, have the better metal stems installed (longer ones of course) and bend them slightly til they stick out the hole in the hubcap. I did this before I purchased my aluminum wheels.
Beginner
Beginner is offline   Reply With Quote
Old 11-12-2006, 09:29 PM   #4
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I inflate my tires to the pressure on the sidewall, 65psi, which gives me some reserve capacity. Then I look at daily, kick them or hit them with a tire wrenc h. I don't check the pressure but, weekly. This summer, I was losing about four lbs per month and we were on a caravan moving every 3-4 days.
You can go to www.myerstiresupply.com and they sell high quality european manufactured valve extensions that work great. Don't use the cheapies that you can buy at wally world.
wingfoot321 is offline   Reply With Quote
Old 11-12-2006, 11:14 PM   #5
New Borockton , Alabama
Images: 21
Why do you stop and attempt to put air in at the first stop every day? If you have a known leak I understand. If you want to know the pressure before you pull out, look at the PressurePro. If you have short stems that are hard to reach, longer metal stems are the best option. Extenders might work but have a bad reputation for leaking.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
