Old 01-12-2010, 09:06 PM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Question Tire pressures for new radials
I just installed 225 X 75 X 15 ST Tow Master tires on my 22 Argosy
(3360 lbs empty and maybe 4000 loaded). I wonder what the pressure should be set at. The manual calls for 40 psi on 700 X 15 bias ply, dealer I bought it from said 50 psi for most trailer tires. The Goodyear dealer tech put them at 65, (their max pressure) (so I reduced to 50, feeling to much since they stood up straight, no radial bulge).
Any ideas or tecnical specs on replacement tires?
arcamedies is offline   Reply With Quote
Old 01-12-2010, 09:55 PM   #2
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
The dealers always overinflate to be sure and seat the beads especially on old rims.
I like your 50psi. The Goodyear or Michelin web sites have inflation for load charts. Haven't looked at one for quite a while but, I have no concern that you are safe at 50psi.
wingfoot321 is offline   Reply With Quote
Old 01-13-2010, 08:52 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Find the inflation vs load chart. Goodyear (I know a four letter word) has them on line. My trailer weight can be 7,100 to 10,000 lbs. I inflate accordingly. I have been running around 9,000 lbs so I am running close to the upper end of inflation pressures.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2010, 10:20 AM   #4
1975 29' Ambassador
Reno , Nevada
on a trailer, run tires at max sidewall pressure.
Old 01-13-2010, 10:25 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Here is the load/inflation chart from Goodyear. http://www.goodyear.com/rv/pdf/rv_inflation.pdf.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-13-2010, 11:44 AM   #6
1980 31' Excella II
Drummond Island , Michigan
You did not specify what load range your tires are. Load range D tires are generally 65 lbs. pressue max load and the max load the tire will carry is specified on the tire side wall. So do the math add up what the max load the tires will carry vs. what your rig weighs. Obviously running the tires at max pressure will definetely be more than what you need with a wide margin but will create a harsher ride because the tire sidewall cannot do not flex as much. So if you go to the charts and come up with a pressure that will handle the weight of your rig plus a safety margin of about 10 % you should have a safe rig, get good tire wear and a nice ride.
Ahzmyrah is offline   Reply With Quote
Old 03-11-2010, 01:19 PM   #7
1978 28' Ambassador
Savannah , Georgia
OK, here is a basic math question: what rig weighs divided by four (tires)? This gives you the load per tire? Then adjust tire pressure accordingly? Thanks. Jack
Skamper1 is offline   Reply With Quote
Sierra 2500HD tire pressures? Wingeezer Tow Vehicles 10 11-24-2008 09:10 AM
Tire and Air Bag Pressures DonaldW General Motorhome Topics 2 04-13-2008 11:27 AM
interstate tire pressures xrvr Sprinter and B-van Forum 11 09-08-2007 07:58 PM
Motorhome Tire Pressures swebster General Motorhome Topics 11 01-06-2006 08:57 AM
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
