Old 10-11-2007, 11:35 PM   #1
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
tire pressurer again
i read the threads on tire pressure, Stil confused.
I'm running single axle '64 Safari 22'aistream with Casrlisle USA Trail ST225/75D15, tires load range D, 4 ply nylon cord. Running them at 65 PSI cold as stated on the side wall. Anybetter ideas? more/less
Walter
What trouble can water in the airline ceause in the tire?
LOt of moisture coming from the fill up hose.
wALTER
Safari64 is offline   Reply With Quote
Old 10-12-2007, 06:55 AM   #2
richinny's Avatar
2011 34' Classic
the water can collect and freeze in the tire and cause an imbalance while spinning. worse yet, the water in the valve can freeze and cause the valve to leak as the tire heats up while you're driving. the rims can rust.
Ricky
Old 10-12-2007, 07:24 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I only fill my tires from my compressor (when home). I drain the tank at least once a month to remove any moisture and I have a filter on the output to remove any water from the air. I live in a very dry area and still remove a great deal of water from my unit.
Richard
Old 10-12-2007, 08:48 PM   #4
1989 34' Limited
toronto , ontario
CATERPILLAR uses only CO2 to fill all of their expensive tires to prevent corrosion and oxidization within the tire and rim.
drive safe
letsgo123 is offline   Reply With Quote
Old 10-12-2007, 09:04 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Walter
wALTER
Walter,
fundamentally, there is nothing wrong with your 65lbs pressure. However, since you have load range D tires, and plenty of reserve capacity, plus you'r ein cool weather, you could lower the pressure to about 50lbs, get a smoother ride that way, and perhaps make things a little easier on the trailer. You will still have plenty of carrying capacity at 50lbs on load range D tires.
Moist air in the tires is not necessarily a good thing...but just putting in nitrogen or CO2 won't help much either, since the moisture most likely has already condensed inside to water.
If you're worried, have the tires removed, everything dried up, cleaned, inspected, and then install the tires, and fill thme with either dried air, CO2 ,or Nitrogen. I think, personally, that dry air will do just fine.
Uwe
www.area63productions.com
Old 10-12-2007, 11:29 PM   #6
Safari64's Avatar
1964 22' Safari
Thanks for the help.
Sounds like dry air and lower pressure is the ticket.
I’ll lower the pressure a bit and enjoy the ride. I'll also get a dryer for my compressor air line.
We used to service aeroplane tyres with Nitrogen but it’s not always a handy item to find at small bush airfields.
I expect moisture in the tyres will condense and freeze and throw balance off until wheel turning warms things up then it might cause wheel corrosion.
Old 10-13-2007, 03:51 PM   #7
1989 34' Limited
toronto , ontario
correction I should have said nitrogen not CO2. what was I thinking?????
sorry, drive safe
Old 10-13-2007, 06:19 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
I use a blend of nitrogen (78%) and oxygen (21%) along with traces of other elements. I have listed the blend I use below. I call it air.
Richard
TV Tire Size campadk Tires 34 09-04-2006 09:44 PM
Tire ? Stream 1529 Tires 8 08-04-2006 10:55 AM
MH Tire presure? donnall Airstream Motorhome Forums 22 03-20-2004 08:03 PM
What is behind my tire? jkenny Axles 6 01-21-2004 01:21 PM
tire pressure Land Yacht Deb Tires 1 01-18-2004 12:50 PM
