Old 06-08-2015, 08:16 AM   #43
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by CapriRacer View Post
OK, 6084# / 4 = 1521# (4 tires holding up the weight)
1521# * 1.15 = 1750# (accounts for side to side and front to rear load variation)
1750# * 1.15 = 2011# (Load the tire to no more than 85% of its rated load)
So I get 55 psi.
So what makes you think 60 psi is not correct?
Thanks very much for this. I was not getting my head around this thing and now that you have shown me the math I think I am.
I did not know if my 60 psi was right, wrong or indifferent. It was simply a guess on my part.
So is the conscious that I should lower my psi to 55 or just leave it as it is?
Thanks again
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-09-2015, 08:01 AM   #44
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Leave it like it is, if it ain't broke ,don't fix it
Cargo Carrying Capacity (CCC) of 23' Safari SE LS OrangeKid 2007 Safari SE 45 04-05-2010 08:26 PM
Cargo Carrying Capacity for 2009 Bambi pattimarty 2005 and newer - Bambi all models 22 03-11-2010 12:10 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Carrying Canoe on top of 1971 Safari Larry71 1969 - 1973 Safari 30 08-02-2005 09:48 PM
