Old 05-11-2019, 05:23 PM   #1
otorvund's Avatar
2018 22' Sport
ISSAQUAH , Washington
tire pressure question
I have now installed TPMS TireMinder on my trailer tires. I have always set my tires to 80 psi before leaving on trips which is according to the manual. Now we see that the pressure goes up to 94 sometimes when we drive - especially in hot weather.
Is that OK - or should I bleed the tires a bit to get closer to 80?
On the tires it states that Max PSI = 80.
Tire type is Goodyear Endurance ST
otorvund is offline   Reply With Quote
Old 05-11-2019, 05:50 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
There are lots of people on this forum that swear by inflating those tires to 70-75 pounds cold both to deal with the pressure increase on hot days and to reduce the stress on rivets from an overly firm ride. I used to inflate mine to 80 as you do but have backed off to 75 of late.
daleyocum is offline   Reply With Quote
Old 05-12-2019, 12:00 AM   #3
2018 28' Flying Cloud
Fairfield , California
Based on this site research, I run 55 psi cold in my GYE's (59-62 hot) and so much better ride. Even at 55, I am still slightly above the recommended psi according to the GYE chart. I ran at 80 psi when we first got our AS because the dealer made it sound like it was an absolute must, but it was like having solid rubber or foam filled tires. Maybe the must be at MAX psi mindset came from the Goodyear Marathon era, I don't know.
StuartsDad is offline   Reply With Quote
Old 05-12-2019, 07:44 AM   #4
CapriRacer
CapriRacer's Avatar
I'm in the , US
No, do NOT EVER bleed down a hot tire. Wait until it has cooled before you approach it. (takes an hour and a half.)
Second, tires are designed for pressure buildup. Their burst pressure is several times the max pressure. The max pressures listed are for COLD tires (that is, tires that haven't been operated for a couple of hours.) Hot tires will have higher operating pressures - and that's by design.
Further, you may be experiencing normal pressure buildup. Allow me to explain.
Yes, the rule of thumb says that you shouldn't get more than a 10% pressure buildup - discounting the ambient temperature affects. If you do, you need to plan to fix that by getting more load carrying capacity or slowing down.
If you experience more than 15%, you need to fix this immediately - first step being slowing down, followed by more load carrying capacity as soon as possible (within a day).
Ambient temperature affects? Tire pressure will increase 3% for every 10įF rise in ambient temperature.
So while you are reporting a 17 1/2 % pressure buildup, most of that could be due to the increase in outside air temperature.
CapriRacer
Please visit my website: http://www.barrystiretech.com/index.html
CapriRacer is offline   Reply With Quote
Old 05-12-2019, 12:29 PM   #5
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Thereís also going to be quite a difference between the tires that are getting direct sunlight and the ones on the other side. After all, the tires are black.
KK4YZ is offline   Reply With Quote
Old 05-13-2019, 08:55 AM   #6
otorvund's Avatar
2018 22' Sport
Good info from everybody. Thank you all
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 10:19 AM
Tire pressure and tire temperature questions Stewball On The Road... 20 01-17-2017 06:52 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
Tire Problem? Pressure Question montanaandy Tires 1 04-22-2003 09:56 PM
