Old 03-24-2011, 05:43 PM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by dznf0g View Post
If you're running "d" rated tires or greater, you should have metal valve stems anyway, due to higher pressures required.
The rating of the tire does not determine the pressure the tires are run at. That is a function of the weight on the tire. I run 45 lbs in E rated tires on the trailer and 50 lbs on E rated tires on the truck.
2004 Excursion 4x4
Old 03-24-2011, 05:49 PM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I chose the Dill system. Sensors are internal and monitor PSI and Temp. Alerts for either, system cycles between wheels showing PSI, Temp check is a button push.
TPMS adds a very reassuring feeling for the tires that you can't see, even with dilligent pre trip inspections.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-24-2011, 11:39 PM   #17
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I'd recommend metal valve stems no matter what kind of time you have. Shortly after getting the PressurePros we had a rubber stem fail (luckily the PPro sounded an alarm and got us off the road before bad things happened)... I am convinced the failure was because of the extra stress on the stem... We now have metal stems.
TB & Greg and Abbey Schnauzer
#3954
Old 03-25-2011, 06:35 AM   #18
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
The metal stems need to be the real deal. Held in by a nut in the back and not the truck stems used by some that are retained by the rubber pull through. It makes no difference if the tire is turning or stationary as a spare, vibration will fatigue a stem with a monitor hanging on it.
Prickly Pear is offline   Reply With Quote
Old 03-25-2011, 10:24 AM   #19
2007 19' Bambi
Peoria , Arizona
I use TST Truck System Technoliges whis has been great for me
Gil Reinke is offline   Reply With Quote
Old 03-25-2011, 10:28 AM   #20
dznf0g's Avatar
Oswego , Illinois
Ouch! That position has been much debated on these forums. I'm not sure which camp I'm in anymore. Let's not go there. But metal is better for all the above reasons....don't cost that much anyway.
tire pressure
Another Water Pressure Question lsmith Fresh Water Systems 3 04-03-2011 09:20 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
