Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 03-13-2010, 12:10 PM   #1
Profile:  2010 27' FB Classic
Ft.Worth , Texas
Tire Pressure Monitor Systems
I have read threads on the monitor systems but the ones I saw are a little dated, so I wanted to hear what is the latest and greatest out there and any and all recommendations for same.
I'll need a system for 10 tires, and able to have different tire pressures on different axles.
Vendors please chime in too. As time go by electronics are changing rapidly so that is my reasoning for a needed update and because I will be purchasing soon.
Old 03-13-2010, 12:23 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
I have an interest in the same info. Which systems are the best for the buck?
Brian
SuEllyn & Brian McCabe
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 03-13-2010, 12:46 PM   #3
Cat Controlled Airstream
w7ts's Avatar
Profile:  2010 31' Classic
Longmont , Colorado
Airstream Registry
After looking around for a while last fall, this is what I settled on.
TIRE PRESSURE MONITORING SYSTEM
Ken
w7ts is offline   Reply With Quote
Old 03-13-2010, 01:02 PM   #4
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
Dearborn , Michigan
This is what we've been using for the last 1,000 or so miles...
RV Tire Systems
I don't think I'd recommend it.
Reasonable price, customer service is great, but in such short time we've had 2 bad sensors. One got all locked up (the head spins freely on threaded valve stalk) with dirt/sand, and other died. What concerned me was when the one sensor died, there was no warning that I wasn't getting any signal from that tire... after who knows how long, I noticed (it cycles thru tires) one with a "0" reading.
We'll see how it goes this coming travel season... anymore trouble, and I'm going to switch to an inside tire/rim mount style.
finalcutjoe is offline   Reply With Quote
Old 05-04-2010, 02:34 PM   #5
The Hawk's Lair
cooperhawk's Avatar
Profile:  1985 34.5' Airstream 345
BACK WOODS , Minnesota
RV Tire Systems
We have used this system for a couple years and love it. It is now sold by Camping World.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-13-2010, 12:56 PM   #6
guy99's Avatar
Profile:  1984 31' Airstream310
Dunsmuir , California
Images: 16
I have had the Smart Tire system for several years. It has help me avoid several destroyed tires (or worse).
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-13-2010, 01:28 PM   #7
gsmithii's Avatar
Profile:  2006 25' Safari
Virginia Beach , Virginia
What a great time for this topic. We will replace tires soon and intend to put a pressure monitoring system aboard. Eight tires, four axles (natch!) with different pressures on the TV front & rear. We are interested in ease of installation and power supply in addition to accuracy and reliability.
Thanks for getting this started.
Skip
Speed is Life . . . guidance is optional . . . it's the stop that can kill you.
2006 Safari 25ss
2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 03-13-2010, 01:34 PM   #8
Profile:  1986 31' Sovereign
Miami , Florida
Airstream Registry
We have used the Pressure Pro (the plain old one) for four years now. Needed it twice and both times it worked as advertised.
Simple to set up and will monitor 16 tires. You set the default pressure during setup so different pressures for trailer vs tow vehicle no problem.
I did make the mistake of using standard issue valve stem extenders only to have one let loose from metal fatigue... Now have all metal valve stems on the Airstream and no probs whatsoever.
mike
Old 03-13-2010, 02:21 PM   #9
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
We, too, have been very happy with our Pressure Pros...we can vouch for their effectiveness and their ease of installation and use. Whatever brand you get, you'll be glad you have something to monitor pressure with. It makes life on the road less stressful. (Do get metal vale stems, though.)
TB & Greg...& Cockers Annie & Sadie
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside Our Bambi: AZBambi Décors
Old 03-13-2010, 10:46 PM   #10
Ft.Worth , Texas
Thanks everyone this is a good starting point for me.
I have only had 2 flats on a trailer in my lifetime but that was 2 to many. Both times I had no idea anything happened until people pulled alongside, passing me real fast and pointing toward the ground.
One of these systems sounds like the best way to go since my truck didn't have the option when I bought it.
Old 05-03-2010, 01:47 PM   #11
I approve of this message
ostream's Avatar
Profile:  2006 28' International CCD
Redmond , Washington
I went with PressurePro and added additional sensors for my tow vehicle as well. It's now available @ Coscto (online), FYI.
ostream is offline   Reply With Quote
Old 05-03-2010, 03:30 PM   #12
Ft.Worth , Texas
Thanks for all the replies. I lost track of this thread with lots of other stuff happening. But I did receive my Hawkshead tire monitor system the other day in the mail. I have not had a chance to get it set up yet or even read the instructions yet.
The main thing is that now I have a way to keep an eye on the tires air pressures and temps. while traveling.
Old 05-03-2010, 04:58 PM   #13
Aviator's Avatar
Profile:  1997 34' Limited
Peachtree City , Georgia
Airstream Registry
I just ordered a Pressure Pro from Sean at ProPride. I will post my impressions when it arrives and as I use it.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Aviator is offline   Reply With Quote
Old 05-03-2010, 10:17 PM   #14
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
My Pressure-Pro saved me when I ran over a sheet-rock knife on the road and the blade was left in the tire. I had an almost instant alarm and could see the pressure counting down in that tire.
Whenever I am at a stoplight or other safe place, I step through all of my tires looking for any one that stands out as higher or lower than the rest. Sunny side of trailer is usually about 2 PSI higher than shady side due to heating.
The Pressure-Pro gives me a feeling of confidence that I am not going to tear up the side of my trailer.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster #9632
TAC TX-10
tire pressure monitor adotutu Tires 124 09-18-2009 04:01 PM
Systems monitor Jack46 2006 International CCD 4 05-20-2008 08:06 PM
PressurePro Tire Pressure Monitoring Systems PatMcFall Commercial Listings 0 12-28-2007 02:04 PM
Tire pressure monitor Stream 1529 Tires 17 07-10-2007 08:37 AM
Tire Pressure Monitor Tin Hut Tires 4 01-11-2005 07:06 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
