03-13-2010, 12:10 PM
2010 27' FB Classic
N/A
Tire Pressure Monitor Systems
I have read threads on the monitor systems but the ones I saw are a little dated, so I wanted to hear what is the latest and greatest out there and any and all recommendations for same.
I'll need a system for 10 tires, and able to have different tire pressures on different axles.
Vendors please chime in too. As time go by electronics are changing rapidly so that is my reasoning for a needed update and because I will be purchasing soon.
03-13-2010, 12:23 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I have an interest in the same info. Which systems are the best for the buck?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-13-2010, 12:46 PM
Port Orchard
After looking around for a while last fall, this is what I settled on.
TIRE PRESSURE MONITORING SYSTEM
Ken
03-13-2010, 12:56 PM
1984 31' Airstream310
Dunsmuir
I have had the Smart Tire system for several years. It has help me avoid several destroyed tires (or worse).
1984 310 Limited Motorhome
03-13-2010, 01:02 PM
2008 30' Classic S/O
Dearborn
, Michigan
This is what we've been using for the last 1,000 or so miles...
RV Tire Systems
I don't think I'd recommend it.
Reasonable price, customer service is great, but in such short time we've had 2 bad sensors. One got all locked up (the head spins freely on threaded valve stalk) with dirt/sand, and other died. What concerned me was when the one sensor died, there was no warning that I wasn't getting any signal from that tire... after who knows how long, I noticed (it cycles thru tires) one with a "0" reading.
We'll see how it goes this coming travel season... anymore trouble, and I'm going to switch to an inside tire/rim mount style.
03-13-2010, 01:28 PM
2013 30' Flying Cloud
Virginia Beach
, Virginia
What a great time for this topic. We will replace tires soon and intend to put a pressure monitoring system aboard. Eight tires, four axles (natch!) with different pressures on the TV front & rear. We are interested in ease of installation and power supply in addition to accuracy and reliability.
Thanks for getting this started.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
03-13-2010, 01:34 PM
1986 31' Sovereign
Miami
We have used the Pressure Pro (the plain old one) for four years now. Needed it twice and both times it worked as advertised.
Simple to set up and will monitor 16 tires. You set the default pressure during setup so different pressures for trailer vs tow vehicle no problem.
I did make the mistake of using standard issue valve stem extenders only to have one let loose from metal fatigue... Now have all metal valve stems on the Airstream and no probs whatsoever.
mike
03-13-2010, 02:21 PM
2006 19' Safari SE
Tucson
We, too, have been very happy with our Pressure Pros...we can vouch for their effectiveness and their ease of installation and use. Whatever brand you get, you'll be glad you have something to monitor pressure with. It makes life on the road less stressful. (Do get metal vale stems, though.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
03-13-2010, 10:46 PM
2010 27' FB Classic
N/A
Thanks everyone this is a good starting point for me.
I have only had 2 flats on a trailer in my lifetime but that was 2 to many. Both times I had no idea anything happened until people pulled alongside, passing me real fast and pointing toward the ground.
One of these systems sounds like the best way to go since my truck didn't have the option when I bought it.
05-03-2010, 01:47 PM
I approve of this message
2006 28' International CCD
Redmond
I went with PressurePro and added additional sensors for my tow vehicle as well. It's now available @ Coscto (online), FYI.
05-03-2010, 03:30 PM
2010 27' FB Classic
N/A
Thanks for all the replies. I lost track of this thread with lots of other stuff happening. But I did receive my Hawkshead tire monitor system the other day in the mail. I have not had a chance to get it set up yet or even read the instructions yet.
The main thing is that now I have a way to keep an eye on the tires air pressures and temps. while traveling.
05-03-2010, 04:58 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I just ordered a Pressure Pro from Sean at ProPride. I will post my impressions when it arrives and as I use it.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
05-03-2010, 10:17 PM
Contributing Member
Austin (Hays County)
My Pressure-Pro saved me when I ran over a sheet-rock knife on the road and the blade was left in the tire. I had an almost instant alarm and could see the pressure counting down in that tire.
Whenever I am at a stoplight or other safe place, I step through all of my tires looking for any one that stands out as higher or lower than the rest. Sunny side of trailer is usually about 2 PSI higher than shady side due to heating.
The Pressure-Pro gives me a feeling of confidence that I am not going to tear up the side of my trailer.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
05-03-2010, 11:28 PM
2005 22' Safari
Gresham
, Oregon
We installed the Pressure Pro prior to our last trip. We were able to see the pressure of the tires easily.The cost of the system is a bit much. But not too much as we feel tmuch safer. And since safety is of very important to use it seems to be worth i t
05-04-2010, 11:46 AM
2010 27' FB Classic
N/A
Most people on this site have gone with the Pressure Pro monitor.
Since I went the different path and bought the HawksHead system I will do a follow up on it once I have it up and running so you guys can compare.
Today, I should take delivery of my trailer so it might be a week or so before I post about it.
05-04-2010, 02:34 PM
The Hawk's Lair
1985 34.5' Airstream 345
BACK WOODS
RV Tire Systems
We have used this system for a couple years and love it. It is now sold by Camping World.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
10-19-2010, 05:03 PM
Dearborn
, Michigan
RV Tire Systems
Note: This comment was for the original, discontinued model (non-replaceable batteries)
10-19-2010, 05:15 PM
2007 30' Classic S/O
Somewhere
, South Carolina
I installed the Dill TPMS. The sensors go inside like OE car designs and are coded so you can set the wheel position to the monitor if you rotate. They monitor pressure and INTERNAL wheel temperature. The screen mounts like a windshield GPS, but a bit clumsy IMHO and it cycles between all 4 positions and displays to 1/10 PSI. You select the button and it shows the temp for the selected wheel. Alarms for temp and PSI.
I have only about 1,000 miles on it and the system does not make up for your neglect but it certanly adds a significant peace of mind factor and in fact on this last trip it showed me a hotter wheel, investigated and found a sticking caliper, RR. Might be caliper related, might be brake hose kinking under braking compression or a turn, unknown but being investigated.
I vote for TPMS.
10-19-2010, 05:21 PM
2005 30' Classic
Burlington
, Ontario
I have the Hawkshead monitor that a couple of other folks here have mentioned. Used it on a couple of trips and happy with it so far. I like the fact that you can replace the batteries in the transmitters - I buy the batts from Hong Kong over ebay at bargain prices!
The Hawkshead system can be bought with a signal repeater for use on longer trailers for about $60 - I bought if for our 31' trailer just to ensure a good signal - maybe I could have gone without it.
This system gives both tire pressures and temperatures and will tell you if you have very slow loss of pressure, medium leaks, or blowouts.
I don't imagine the temperature readings would be all that accurate, but at least it gives you an indication if one wheel is running a lot hotter than the others and should be looked at.
So far, since I installed the system, I haven't had any tire problems, but just having the TPMS and being able to check all pressures/temperatures whenever I want something to do on a long drive as well as knowing that I will get automatic warnings of developing problems is great for peace of mind! Would buy again.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
