Old 09-16-2011, 08:20 AM   #57
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by dznf0g View Post
Most, if not all, TV OEM mfrs use sensors which have a motion switch incorporated in them. That's why they have an estimated life of 10 years. I am unaware of any of the valve stem sensors which are switched, thus the shorter battery life. They switch on whenever there is air pressure applied (installed on the stem). That's why I remove mine whenever parked for more than a day or so.
Tire Stat by Mobile Awareness are switched by motion. You can also air up the tire without removing the sensor.
Cheers, Dan
Old 09-16-2011, 08:24 AM   #58
Here is a link.
Transportation Safety Products
They are spendy but a high quality commercial unit.
Old 09-16-2011, 11:55 AM   #59
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Smartstream View Post
Here is a link.
Nice, but, WOW....$685?
Old 09-16-2011, 11:57 AM   #60
dznf0g's Avatar
Oswego , Illinois
Originally Posted by nvestysly View Post
I like that idea if it substantially increases battery life. I may not remove them if we're traveling from place to place and only stopping for a day or two. But it would certainly make sense to remove them if the rig is stored for a few weeks (or months).
I've heard others say the set-up can be tedious. Do you have to go through the same set-up procedure when you re-install the sensors? Do you simply mark the sensors and put them on same tire. We have not purchased a system yet so I don't understand all the details.
Thanks for the info.
Lucius
No, re setup required, at least on the Doran.
Old 09-16-2011, 09:33 PM   #61
Ag&Au's Avatar
Port Orchard , Washington
I left the Hawks head sensors on our TV for nearly a year without changing the batteries. I only changed them when I did because it was convenient. They had not yet stopped functioning. However, our truck only gets driven a few times a week when not towing. Since we have three vehicles for two drivers, the truck only gets about 8000 miles a year. I take the sensors off the trailer when it is in storage only for security. The TV without the trailer will cause the control unit to alarm every once in a while, but it is really not a nuisance.
If you mark which wheel the sensors came from and place them back in the same place you do not have to set them up again. However setup is pretty straight forward and doesn't take much time.
I haven't taken the time to figure out why the control unit usually doesn't mind that the trailer isn't there, but every once iin a while does.
If I take the sensors off the trailer and leave them on the truck, it seems to go more smoothly if the trailer is not in range of the truck when I do.
Ken
Old 09-18-2011, 02:31 PM   #62
HowieE's Avatar
Princeton , New Jersey
Images: 12
i am not sure why a system would have a motion switch in the sensors because that would mean you would not get a signal of a low tire until after you were on the road.
I attempted to use the Fleet Specialties system, a system designed for the over the road industry. with very poor luck.
I would get a low pressure indication on one tire every day the morning temperature was below 35 degrees. That sensor was replaced. On the road I got low pressure indications from 2 tires that were in fact above the set point. All 10 sensors were sent back and replaced but I have no faith in the system so it sits on the shelf.
As for battery life and removing the units when not in use. You should have to put an isolator ape or paper between the unit and the battery or the unit will be transmitting a low signal until the battery dies. The sensors are energized as long as the shipping isolator is removed they will draw full radio transmission current.
From my experience and the comments here I do not thing this technology has been perfected to a point that warrants buying a system. I think I have cut my losses at this point to the original purchase price.
2004 Excursion 4x4
Old 09-18-2011, 03:11 PM   #63
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Howie, for me, having a Hawkshead system for only one 6000 mi. trip this summer has more than paid for the system. One could cut the loss of a wheel well with just one incident of a tire going flat and thump thump thumping its way through and around your wheel well.
On this one trip the system alerted me to a slow leak that I watched for several days and then decided it must be real. Turned out to be a roofing nail after going through tornado repair areas around N. Alabama. The tech advised if I had kept running on it, that it surely would have eventually torn up the tire.........
2 Blowouts going across 4 corners area surely alerted me in time to get pulled over almost immediately and averted any damage...........All this to say, if you have never seen or experienced wheel well damage and the thousands to fix or repair.........having a TPMS is small change......Do what YOU need to do........God bless.......Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 09-18-2011, 03:53 PM   #64
HowieE's Avatar
Images: 12
Dennis
I am happy that you have had good luck with your system and hope most others will be able to post the same results. However i feel obligated to post my results especially when they are so far from what one would have expected from a Safety Product.
Just yesterday I had a conversation with another member in my unit and his results were along the same lines as mine. Different manufacture but not good results thus my comment on the technology.
2004 Excursion 4x4
Old 09-19-2011, 06:04 PM   #65
2009 25' SS International
Pasadena , California
i feel the same than you... if you can't rely on a system to work flawless, what's the point of false security?
i might be ok with using it if i would just know that it might not alert me when disaters strikes, but worse in my case consistent false warnings (low battery, no sensor) made it impossible to keep the system on after repeated and fruitless attempts to resolve the problem...
so my point is the system was so faulty that i had to turn it off and remove sensors because i didn't want to hear the beeping anymore and be alerted that on of my tires had no pressure/or signal
who was it again who wanted to by some brandnew sensors from me?
flmgrip is offline   Reply With Quote
Old 09-19-2011, 06:48 PM   #66
Ag&Au's Avatar
What TPMS were using?
Ken
Old 09-20-2011, 08:03 AM   #67
Ken
hawskhead HD (with user exchangeables batteries)
Old 09-20-2011, 08:50 AM   #68
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
I have used PressurePro for years now with never a problem. The system has saved my possible trailer damage twice and I would not be without it.
John W. Irwin
WBCCI #9632
Old 09-21-2011, 07:59 PM   #69
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
That's what I have and they have worked flawlessly for 2500 miles and saved my bacon on 2 occasions with flats.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
tire pressure monitor adotutu Tires 124 09-18-2009 05:01 PM
Systems monitor Jack46 2006 - 2010 International 4 05-20-2008 09:06 PM
PressurePro Tire Pressure Monitoring Systems PatMcFall Commercial Listings 0 12-28-2007 03:04 PM
Tire pressure monitor Stream 1529 Tires 17 07-10-2007 09:37 AM
Tire Pressure Monitor Tin Hut Tires 4 01-11-2005 08:06 PM
