Old 10-04-2014, 03:09 PM   #113
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Rick,
No problem with the long story. It's refreshing to hear a good story about a flat tire.
Ken
Old 10-04-2014, 03:48 PM   #114
rperrym's Avatar
2017 28' Tommy Bahama
Hot Springs Village , Arkansas
Thanks Ken. If I only had metal valve stems on my 16" Michelins, I would install TPMS on the AS.
Rick
rperrym is offline   Reply With Quote
Old 10-04-2014, 04:39 PM   #115
Ag&Au's Avatar
Rick
I discussed that metal stem thing with both Hawkshead and Discount Tire. The Discount Tire manager pointed out that regular stems (at least the ones they use) are metal with a rubber shell. The owner of Hawkshead said the only reason he carries metal stems is that he got tired of trying to convince buyers that they don't need them.
I have used my Hawkshead HD 4 for over five years with 15 inch ST tires and 16 inch LT tires on the trailer and 17 inch LT tires on the truck with very reliable pressure and temperature readings with only the stems that Discount Tire regularly uses on truck tires.
I monitor 10 tires including both spares.
Ken
Old 10-04-2014, 07:38 PM   #116
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
When I went to Discount Tire and had metal valve stems installed, the dealer asked me to promise him I wouldn't inflate the tires beyond the recommended PSI because in his experience metal valve stems are usually installed for high pressure applications. So, I promised.
Rocinante is online now   Reply With Quote
Old 10-04-2014, 08:30 PM   #117
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
""I have been using "Tire Minder" The sensors screw right onto the valve stem and give you pressure and temp.""
Ditto Purman's post # 7 above. I run the Tire Minders on my 4 Maxxis 8008 STs. The 10 ply Maxxis are so overbuilt for the weight they carry on my 30, but I want to keep track of the temp and pressure anyway. I think everyone can agree that under inflation and high temps will kill any tire that's being asked to carry a load. Full time monitor of your tires can only be a plus.
T Minder Cust service is great with any problem or replacement part.
Howard L. is offline   Reply With Quote
Old 10-04-2014, 08:36 PM   #118
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Tire pressure monitor recommendation?
I've been using the Tireminder as well, and have been very happy with it. The one I'm using will read up to 22 sensors and I don't require the booster between my TV and 28'.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-09-2014, 08:40 AM   #119
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Tiremimder and Tire Traker seem to be the same product looking at my Tire Traker system. Tire Traker offers good service too. I just ordered new O rings and batteries from them and the order was shipped promptly and arrived in a few days.
Kelvin
