Old 09-03-2014, 09:59 PM   #85
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I'm the opposite, spent the TPMS money towards new 16" Michelins, which have little to no blowout history. I read tire temps each fuel stop along with my normal walk-around to check security of things. TPMS reduces the chance, but may not protect the trailer from damage with a sudden tire blowout.
Doug and Cheryl
Old 09-04-2014, 09:24 PM   #86
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
I am leaning more toward preventative medicine. We live in California and during the summer, the roads and temperature can get pretty hot in the valley. If spend $600 on a possible prevention, it will be money well spent. We went to an AS rally and met folks who had a blow-out. While the damage was relatively minimal, it will still be considerably more than a set of monitors. I hope it works in my favor!
Ron
Ronman is offline   Reply With Quote
Old 09-04-2014, 10:04 PM   #87
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I like the constant check the system provides. I can see if tires are overheating, over pressure, etc, without stopping.
The technology is there and it works well for us. We learned that tires are running similar in heat and pressure variations. This would be helpful in catching a "problem" and trying to stop before things really go north.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-04-2014, 10:14 PM   #88
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I agree. TPMS's are a great learning tool, if you monitor them while they monitor your tires. They are are of definite value if you ignore them until they alarm. However, if you check them periodically while travelling, you will learn a lot about what temperatures and pressures your tires are subject to during normal use.
Ken
Old 09-04-2014, 10:33 PM   #89
Ronman's Avatar
Bottom line...DO NOT simply rely on anything. Always perform your "Pre-Flight" check. Eyes and hands are the best form of analysis. Tech is just a bonus!!
Old 09-05-2014, 04:52 AM   #90
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm using our new Dill Tpms for the first time. We get a few lost signal alarms every day. I have the remote antenna under the back seat but will try it further back.
Still, it's nice to have it and resetting is easy.
2012 Dodge Durango Hemi/AWD
Old 09-05-2014, 05:52 AM   #91
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Wayne & Sam,
I run my dill antenna on the roof.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-05-2014, 06:08 AM   #92
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I too recently put on the 16" Michelins and am pleased with them - but I still use a TPMS.
Granted a TPMS is no guarantee against blow outs, but what I have read is that blowouts are very often the result of running a tire at low pressure. If a tire developed a leak through road debris, I'd like to know about it S.A.P to prevent it developing to something worse.
As well, I have heard of people having a blow out and not knowing about it until passing motorists alerted them. If I ever I had a blow out I'd like to stop the trailer as soon as I could to hopefully prevent - or at least minimize damage to the trailer.
But as you say there are no guarantees! I just like to do all I can to minimize chance of problems.
In this regard I also still to a walk around at every stop to give the tires a visual and check temperatures - usually just by hand, but also with an IR temp gauge if I suspect something may be developing with one wheel.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-05-2014, 07:12 AM   #93
Ag&Au's Avatar
Your antenna will work best if it is up and in the clear, such as near the rear window. Because of the aluminum trailer and metal TV the sensor signals are bouncing all over the place. You need to have the antenna clear of as much of that metal as possible.
Ken
Old 09-05-2014, 07:45 AM   #94
dznf0g's Avatar
Oswego , Illinois
Doug, I seem to recall one of the tire experts that post here indicated that most blowouts due to defect begin with a leak and progress rapidly to a sudden loss of air. I am not convinced that TPMS won't help in many blowout situations.
I also think, but can't back it up, that most of the damage to the ASes comes from rolling on a blowout for some distance after sudden loss of air. I think a warning from TPMS will at least minimize damage.
I know on my Doran a sudden loss gives you an INSTANT tone, red light and message. You can test any of them by just unscrewing external sensor and timing the warning issuance.
-Rich-
Old 09-30-2014, 12:30 PM   #95
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
Last year we bought the RV Doran TPS sensor kit for my 23' International. Since then, we have rolled over 25,000km and the units worked just fine. Proof of that was on one occasion when the warning light came on indicating one tire was at 40 psi which made me jump for a second, however it was because of the below freezing temperature we experienced over night in South Dakota. The tire soon warmed up once we got going and the warning went out. I knew the sensors were in fact working.
A few days ago, while winterizing my AS I removed the sensors and for one reason or another one of the sensor lockers was bunged up and needed replacement. "Bummer" I thought, "who is going to replace this!"
I contacted Doran with a request for the part and lo, within a day I received a response and within one more day the sensor locker was mailed. This is Customer Service!
I have read reports of the Doran sensors failing but mine haven't and if they do, I feel confident that the service I will need will be there.
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 09-30-2014, 02:43 PM   #96
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
My Dill TPMS has a magnetic antenna holder which I have attached to the inside (bed side) of my truck tailgate and my truck bed is covered over by a cap. Signal has no problem getting through the tailgate to the antenna and I never have dropouts.
The Dill TPMS is one of three components that provide me great peace of mind in my travels. The other two are 16" Michelins/SenDel wheels and a rear view camera system.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 09-30-2014, 03:46 PM   #97
Wayne&Sam's Avatar
Images: 21
I'm with you acstokes.
Just wrapping up our first real trip with our 2014. 30 days, 3,500 miles.
My dill system does drop out once in a while, but I think relocating the antenna will help.
My rear camera system I'd the best thing I added. All these years I never had a good rear view and now I do. I find myself missing it when the trailer isn't hitched!
Old 09-30-2014, 05:54 PM   #98
1994 30' Excella
Mississauga , Ontario
I am using the Hawkshead Talon tpms. It is way superior in signal strength over the Hawkshead that I had previously. No dropouts and it scrolls through the tire readouts continuously.
I'm happy.
Al
Al and Jean
TAC ON-3
