Old 03-29-2007, 08:59 AM   #1
Stream 1529's Avatar
2004 34' Classic S/O
San Antonio , Texas
Tire pressure monitor
With all of the concerns about maintaining tire pressure, and overheating I am giving some thought to getting a tire pressure monitoring system. Has anyone looked into this, or actually purchased a system. I'd really be interested in getting some input.
______Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
Stream 1529 is offline   Reply With Quote
Old 03-29-2007, 10:28 AM   #2
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I've seen some recommendations in the forum for this system: Doran PressurePro Tire Pressure Monitoring Systems : Doran Manufacturing LLC I was wondering about this like you, so I'm glad you started the thread.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 03-29-2007, 10:35 AM   #3
_
fyi guys...
http://www.airforums.com/forum...tem-24526.html
and
http://www.airforums.com/forum...last-8680.html
also tin hut is using the system and seems happy...
http://www.airforums.com/forum...tor-12432.html
cheers
2air'
Old 03-29-2007, 10:41 AM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have the SmarTire which has some advantages (temperature compensation). I like it, has already saved one tire (and maybe avoided worse)
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-29-2007, 12:08 PM   #5
San Antonio , Texas
I was looking at Intellivalve:* The Smart Tire Pressure Monitor System but they don't have one yet that would include trailer axels. I'll look for the SmarTire because I'm looking for one that will also monitor the tire temps.
Old 03-29-2007, 12:56 PM   #6
guy99's Avatar
Images: 16
Smartire is available from camping world -
SmarTire Tire Pressure Monitor - Camping World
I imagine that the quality of installation will vary as it seems to with camping world.
You could install the system yourself - except maybe for the the sensors which are strapped to the rim inside the tire. Good directions are available.
Old 03-29-2007, 01:12 PM   #7
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Pressure Pros
We utilize Pressure Pros for the Airstream as well as the tow vehicle. We're very happy with the system as it's warned us on two occasions thankfully averting damage to the Airstream. We now pay a bit more attention to our max speed and air pressure; especially in hot weather. I leave the monitor attached to the dash, checking the TV pressures periodically.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-29-2007, 01:37 PM   #8
guy99's Avatar
Images: 16
I bought mine here: Welcome to Bob Dickman Tire Center - “The RV &SmarTire Experts” - Smartire RV Systems
If you are going to self install I would consider purchasing from them. Paul is an expert on the system and support and service has been excellent.
Old 03-29-2007, 07:36 PM   #9
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I have had the PressurePro for about a year now, and am very pleased with the quality, accuracy, and dependability. I use the sensors on both the TV and the AS, and consider it a must for single axle trailers.
SilverRanger is offline   Reply With Quote
Old 03-29-2007, 08:17 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Thumbs up Pressure Pro...........
............is simple, accurate and easily programmed. I use one every day for my service van and add the 19CCD when on the road. It's a very versatile system! Overlander 68 is a Pressure Pro distributor, and I have installed close to 30 of these systems on large Mohos and 5th wheels. No problems or complaints.
Some of my clients have the Smart Tire facatory installed on their rigs and they have told me they are having problems reaching the factory with tech problems. Also, if you have a problem with a unit, the wheel must be taken off the rig and the tire removed.
With the Pressure Pro, you just remove the sensor on the end of the valve stem!
I HIGHLY RECOMMEND THEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:cla p:
BTW, The Doran system is simply a re-badged faceplate purchased from Advantage Pressure Pro.......the manufacturer.
Old 04-02-2007, 02:29 PM   #11
1984 31' Excella
Norfolk , Virginia
Images: 11
Tpms
I bought a Pressure Pro and shortly there after suffered belt seperation in it beginning stages but was able to pull over to the curb on the first one before the tire fully deflated and on the second one in the campground on one tire that had lost air, but in servicing the deflated tire noticed the seperated belts (irregular tread surface) on the adjacnet tire.
They do not measure temperature but do not require breaking down the wheel to install, you remove the valve cap and screw on the transmitter/sensor.
One of the sensors (on the other side of the trailer) developed a leak and I had a replacment within days.
Excellent service and tech support.
Beginner
Beginner is offline   Reply With Quote
Old 04-03-2007, 01:27 PM   #12
Viera , Florida
Question Pressure Pro Distributor
Originally Posted by lewster
Overlander 68 is a Pressure Pro distributor....
lewster,
The Overlander 68 in our membership directory knows nothing about this. Was that a typo?
Randy
Old 04-03-2007, 03:36 PM   #13
guy99's Avatar
Images: 16
TRY 68Overlander
Old 04-03-2007, 03:47 PM   #14
Viera , Florida
68Overlander has only posted once to the forum. Are you sure that's the distributor?
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
