Old 04-03-2007, 03:54 PM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It's 68 Overlander (with a space)
http://www.airforums.com/forum...ander-910.html
Richard
Old 04-03-2007, 04:17 PM   #16
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Thanks. I sent him a PM on this.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 04-03-2007, 07:14 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
[quote=lewster].. Overlander 68 is a Pressure Pro distributor, and I have installed close to 30 of these systems on large Mohos and 5th wheels. No problems or complaints.
quote]
Sorry, I was having a mildly dislexic moment .
Old 07-10-2007, 08:37 AM   #18
Viera , Florida
Thumbs up PressurePro Monitor Installed
After reading all the tire troubles Brian (moosetags) had on his recent trip, documented in this thread http://www.airforums.com/forums/f42/...ion-32418.html, I decided to purchase the system based on everyone's recommendations here.
I purchased it from the vendor at the International Rally in Perry. It installed very easily, in about 10 - 20 minutes for the four trailer wheels. I decided to only monitor the four trailer wheels at this time. I think I would know if something was happening on the truck, and a tire failure on the trailer has a great potential of doing some damage to the trailer.
The cold and max pressure recommendations/ratings for my trailer tires are the same, 50 psi. I've pulled about 3000 miles with that setting and no troubles so far.
The PressurePro provides an easy morning tire check. Pressing the arrows on the panel scrolls through all the sensors, so you can see if you are starting at the correct psi. While towing this past weekend in the 95 degree FL sun, I was able to see that the tires had increased about 5 psi. from the cold morning setting.
It's very comforting to know that things are going well back there. I'll never travel without it again.
Randy
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
