Old 07-06-2004, 12:11 PM   #1
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Tire Pressure Monitor
Just ordered these tire pressure monitor/alarms that just screw onto the valve stem and transmit remotely. David T. from this forum has them and can give first hand info on reliability. I'm always worried about what's going on with the tires behind me and this will give me real time data. I'll let you know my experience after I get them. I got the 8 wheel setup so I can monitor the tow vehicle as well.
http://www.doranmfg.com/rvtirepressuremonitors.htm
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 01-11-2005, 08:25 AM   #2
aluminauts's Avatar
vancouver , Washington
Question
Well Tin Hut are you ready with a report about your experiences with the tire monitor system.
Iím thinking of a 6 wheel version and hope you have only good things to say about yours.
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
aluminauts is offline   Reply With Quote
Old 01-11-2005, 08:56 AM   #3
Elgin , Texas
Images: 164
rubber or rigid valve stems?
Tin Hut,
Do you have rubber valve stems or the metal, rigid ones? Does this product specify whether or not it's OK to use with flexible stems? I could see where centrifugal force could cause rubber stems to fail prematurely due to this...
bake315 is offline   Reply With Quote
Old 01-11-2005, 10:51 AM   #4
Tin Hut's Avatar
I'm pleased with the system. I have had a couple of issues with one or two of the sensors on the tire not being picked up consistently. I've talked to several that have the system though and they haven't experienced this. Also, on RVNet there are several users posting their favorable results. On the Sub I have the stock rubber stems. I just replaced the stems on the CCD with metal valve stems and had the tires balanced with the sensors on them. I like the idea of knowing immediately if I'm losing pressure in the tires behind me. Their customer support (PressurePro) has been good and they're working with me on my sporadic problem.
Old 01-11-2005, 07:06 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
We have 3 members of our unit that have them installed. I have bought a set and will have them on in time for my trip to Florida in Feb. One of the members had a tire go slack on him on his way to Florida in November and the monitor caught it. Its easier to pump up a tire and get to a service area than to lose one on the highway. They are not cheap but neither is body work or fires. We had a member that lost his trailer and his van due to a fire caused by a flat tire.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Tow Vehicle Tire Pressure overlander63 Tow Vehicles 17 04-30-2004 11:43 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Tire Problem? Pressure Question montanaandy Tires 1 04-22-2003 08:56 PM
