Old 07-05-2008, 10:48 AM   #1
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Tire Pressure Gauges- Pressure Varies!
I have always used the "stick" pressure gauge to check my tire pressures. I also noticed that from the two stick gauges used, they would indicate different pressures from the same tire. They also would vary, depending on temperature that affected the center stick with the readings. The tire service would use their "sticks" and have a different pressure... what to do, what to do!!?
Welcome Digital AGE! I have a Craftsman (from Sears) and a Accutire (from Costco) digital readout gauges for a year. These seem to be much closer to being... accurate. Several days ago I had the Tundra's oil changed at the dealership and they checked tire pressures... each had 40psi. Well here are the results at home. The first tire on each guage is the same tire, 1, 2, 3 and 4.
Accutire: 42.1psi, 42.2psi, 42.3psi, 43.2psi
Craftsman: 42.5psi, 42.5psi, 42.5psi, 43.5psi
I will keep the Craftsman in the Tundra as I use it to tow the 23 foot Safari. At least the pressures seemed steady. Although both were pretty close, you can get different readings. The fourth tire and the 43.5psi I retested several times to get 43.5psi.
The Accutire is easier to use than the Craftsman, due to the straight testing position and fits into your palm for a firm fit. The Craftsman is at a 80 degree angle, or so, and sometimes you need several attempts to get a firm fit.
Anybody have a brand of pressure gauge that has worked out well?
To add... I use to sell antique coin operated games and equipment. One sale was a 1930's Mills penny floor scale. One sold to an Advertising Agency and a week later the owner calls and said my scale was not accurate. I asked how did he know? It varied from his home scale. I asked, how did he know his home scale was more accurate than the floor scale? That settled the question, but I told him that the penny floor scales were not intended to be accurate, but close. It is the relative weight each day from the same scale that is important. A doctor's office with an accurate scale can then varify if you need to make the mental adjustments... Depending on how accurate to actual tire pressure your gauge measures, could explain some problems with tires descibed on the forum.
Ray Eklund is offline   Reply With Quote
Old 07-05-2008, 10:56 AM   #2
Tire pressure, after a few miles, can change differently.
If they are not "ALL" balanced correctly, then one, or more that is not, will bounce when in motion.
That in itself, will cause a tire to heat up moreso than one that is properly balanced, yet will return to proper pressure, once it cools down.
Old 07-05-2008, 11:22 AM   #3
Ray Eklund's Avatar
Hi Andy,
I had the oil and filter changed on the 3rd of July and the tires would have been hotter driving to the dealership. My readings are today, July 5th, and are cold tire temperatures. Even though one side of the truck had the sun exposure and the other, not. I would suspect that even that could affect pressure differences.
When I have a cold temperature reading where all tires agree, I would also expect the tires when hot to be close as well, yet higher. Since I am not doing a Consumer Reports trial, I thought this would be a chronic problem when you are taking a tire pressure and no two gauges agree as to the true tire pressure.
Old 07-05-2008, 11:35 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I use the accutire that I bought at Costco. It is very easy to read and gives me the same numbers as the slide type that is on my compressor hose.
Many things can effect the pressure of the tires. Altitude, temperture and even load on the viechle are all factors. The biggest problem I have is checking the tires when they are cold. It hasn't been cold in Phoenix for months.
Richard
Old 07-05-2008, 12:31 PM   #5
richinny's Avatar
2011 34' Classic
you missed your chance on 6/1 ;-)
http://www.airforums.com/forums/569637-post151.html
Ricky
Old 07-05-2008, 01:13 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
You make a good point, except:
It was not in Phoenix and I could not find the tires...
Richard
Old 07-05-2008, 06:41 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Most tire gauges are supposed to be accurate within 1 PSI. In most tire shops, all tire gauges are supposed to be checked for accuracy to a master gauge that has been calibrated. In the real world, of course, it doesn't happen. Just remember that a tire gauge is supposed to give you an idea of how much pressure is in your tires. I have a tire inflator/gauge that is 1 psi low, and another that is 10 psi high.
Old 07-05-2008, 07:22 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I have two long truck gauges Ive had for a while. I used them when I had my big trucks. I still use them today. They are within 1 lb of each other I also have an analog Airing Device and I check against them. If your tires are within one lb of each other and are at what is listed on the tire. NOT TO WORRY. Your GOOD
Mikethefixit is offline   Reply With Quote
Old 07-05-2008, 07:27 PM   #9
Cracker's Avatar
Pittsfield , Maine
Unfortunately, I've thrown away a good number of gauges - and taken several back to the auto parts store because they wouldn't give the same reading, on the same tire, twice in a row! The gauge I use now, for the AS and the dually, cost $36.00, or thereabouts, and it has always been accurate. It is a high pressure gauge (truck type) and it has the bi-directional angled head necessary for dual tires. Apparently higher cost does buy higher quality! I have also found two other low-pressure gauges that have proven to be accurate over time - and I keep one in each of my small cars. With several of the cheaper gauges I could get a substantial difference in the reading depending on the angle of the gauge when it was placed on the tire stem. I'm a tad anal about tire pressures - especially for the duals - normally maintaining the pressure within a one-half pound margin
Cracker
Cracker is offline   Reply With Quote
Old 07-05-2008, 08:07 PM   #10
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Ray
When I purchased my GMC truck I had to upgrade my tire pressure gauge to be able to read up to 80 psi. I purchased an Accu-Gage, dial-type, pressure gauge that reads to 100 psi. The gauge is distributed by G. H. Meiser & Co and is assembled and tested in the USA and comes with a lifetime warranty. You can add a rubber gauge guard and vinyl pouch for a few extra dollars.. I use it to fill the tires and then monitor the tire pressures with the Pressure Pro monitoring system. The Accu-Gage is very accurate and is verified with the Pressure Pro readings. When parked you will see a difference in individual tire pressures as the sun starts to shine on each of your tires. You will also see a large drop in pressure when you hit some low temperatures when your traveling.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 07-05-2008, 08:29 PM   #11
2019 28' International
Leonardtown , Maryland
In the paper work that came with your gage. what was the accuracy of the indicator? 10 %, 5%? In either case the gage probable meets specs.
If my tires are within 2 lbs/sq in I am satisfied.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 07-05-2008, 09:24 PM   #12
2dabeach's Avatar
Rebee
The literature that came with the gauge and their website did not list the accuracy of the gauge. The paperwork indicates that it was tested for accuracy before shipment and that the bronze Bourdon tube movement is not affected by changes in temperature, humitity or altitude. You can check with them at Accu-Gage Tire Gauges
Old 07-05-2008, 09:32 PM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
My accutire is rated at +/- 1% +0.1 PSI. I know what the +/- 1% is, but what is the + 0.1 PSI mean?
Richard
Old 07-06-2008, 06:58 AM   #14
Images: 59
When the accuracy is given as +/- 1%, usually it is the percent of full scale. If the gauge is good for 100 psi, that would be 1.0 psi. Then you add 0.1 psi to that value and the accuracy is +/- 1.1 psi
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
High oil pressure indicated on gauges Mr. D Mechanics Corner - Engines, Transmission & More... 11 11-02-2006 11:28 AM
Tire pressure ardenrj Tires 5 05-09-2005 08:23 AM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
