Old 12-29-2005, 03:36 PM   #15
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by davidz71
Check the sidewall of all of your tires! It will have a max pressure listed. A C Range tire is usually 55 psi max. for a fully loaded trailer. Many run 55 psi no matter how the trailer is loaded to make sure that the tires are never running under inflated. As long as you are running 53-55 psi cold then you are fine but this would range from a lightly loaded trailer to a fully loaded trailer. I know there are charts out there that show what you can run "psi wise" for different loads. I don't trust the charts because I feel that an underinflated tire can cause you heat problems and failure down the road (no pun intended).
A D Range tire has a max of 65 psi so run your tires 63-65 psi. I can't advise running D Range tires at C Range pressures to limit shock to the coach because I found that probably lead to failure of one of my D Range tires.
David,
I was after a temperature reading on properly inflated tires since Jim stated to measure the temperature of the tires at various inflation pressures. I run my tires at 35PSI as that is the recommended pressure on the manufacturer plate and each tire only carries 1450 lbs at the most.
Bill
Just my personal opinion
Old 12-29-2005, 04:18 PM   #16
jimmickle's Avatar
2000 31' Land Yacht
I take an opposite stance on pressure. I got an accurate weight on my trailer when fully loaded and run pressure appropiate to the load. Once you get accurate weight, you can use the Goodyear chart referenced above to determine the minimum pressure that you should run. In the case of my 2002 25 ft Safari, with its ST225/75R15 Load Range D tires, 30 PSI would be sufficient to carry the load. If I didn’t have it loaded to GVW, I would even be OK at 25 PSI (40 PSI below recommended). To have some safety factor, I run my tires at 40 PSI (25 PSI under Airstream’s owners manual recommendations), which gives me excess capacity of about 300 pounds per tire. My tires run nice and cool, even on hot days. My trailer seems to ride smoothly, as nothing seems to jump around, even when we forget to take something off the counter or table before we get on the road.
Just because Airstream recommends higher pressure than is really required, or the tires have a higher maximum pressure, doesn’t mean you have to run the higher pressure and subject your trailer to higher levels of road shock. Overinflation reduces contact patch and subjects your unit to added shock. Go to Goodyear or Michelin's web sites to see what they say about proper inflation, get an accurate weight and inflate your tires properly.
jimmickle is offline   Reply With Quote
Old 12-29-2005, 07:16 PM   #17
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by wkerfoot
David,
Bill
Oops, my fault. It clearly says temp and I was thinking psi.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-29-2005, 07:22 PM   #18
davidz71's Avatar
1986 25' Sovereign
Originally Posted by jimmickle
I take an opposite stance on pressure. I got an accurate weight on my trailer when fully loaded and run pressure appropiate to the load. Once you get accurate weight, you can use the Goodyear chart referenced above to determine the minimum pressure that you should run. In the case of my 2002 25 ft Safari, with its ST225/75R15 Load Range D tires, 30 PSI would be sufficient to carry the load. If I didnít have it loaded to GVW, I would even be OK at 25 PSI (40 PSI below recommended). To have some safety factor, I run my tires at 40 PSI (25 PSI under Airstreamís owners manual recommendations), which gives me excess capacity of about 300 pounds per tire. My tires run nice and cool, even on hot days. My trailer seems to ride smoothly, as nothing seems to jump around, even when we forget to take something off the counter or table before we get on the road.
Just because Airstream recommends higher pressure than is really required, or the tires have a higher maximum pressure, doesnít mean you have to run the higher pressure and subject your trailer to higher levels of road shock. Overinflation reduces contact patch and subjects your unit to added shock. Go to Goodyear or Michelin's web sites to see what they say about proper inflation, get an accurate weight and inflate your tires properly.
Jim,
I had the same stance until I had a blowout with a fairly new tire with low miles. I was running D Range and had them inflated to 55 psi. The 31' trailer was loaded to around 6,000 lbs. according to the local scales and I carried no water on board in any of the tanks.
Craig
AIR #0078
3.73 rear end
Old 12-30-2005, 09:05 AM   #19
JimGolden's Avatar
1977 31' Excella 500
Tire Temps
Well I guess I opened the box here...
I'm not sure exactly what the temp should be. I'll have to check on this and get back to you. My buddy is an ASC Master Mechanic and has one of those infrared thermometers and he would have the details. My understanding is that your tires should never get so hot that you can't lay your hand on them, so I'd think you'd want them under 150 degrees F at least. I'm sure it's a function of the outside air temp too. I'd say in the summer time you'd probably want to keep them down to like 130 or so. There's probably a certain differential temp that is considered correct, like maybe 40 degrees warmer than the outside air temp. I'd think a tire company could tell us that.
Basically, if you run a higher pressure than necessary, the worst thing you'll do is grind the center tread off prematurely. It causes it to wear out quicker than normal, but it's not dangerous (although it will ride rough). Too low and they overheat and come apart. It's best to get it to the proper temp for your setup, but if you have to err, err on the side of overinflation.
If you can get one of those thermometers (they're not that expensive, I just haven't bought one myself yet...just bummed my buddy's), a good baseline would be to check the tire temp on your car. Whatever that comes up as, your trailer should be about the same.
I'll get hold of my buddy when he gets off Christmas vacation and see if I can bum his themometer and do some testing. He uses it a lot for figuring out the optimum tire pressure for his motorcycle. It's REAL bad if one of those tires comes apart. They're also handy for checking radiator temps, hose temps, the teapot on the stove. I really should get one
JimGolden is offline   Reply With Quote
Old 12-30-2005, 10:24 AM   #20
gwsullivan's Avatar
According to the chart above, I can run tire pressures of 30 psi in my 25' Safari (gvwr 6300) and 60 psi on my 30' Limited (gvwr 9100). I have always inflated the tires on the Safari to 60-65 psi and noticed that things bounce around inside. When I tow the Limited with same tires and pressures nothing seems to move around inside. I think I will try running 35 psi on the Safari and see if it makes a difference. Any comments or concerns??
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 12-30-2005, 11:10 AM   #21
JimGolden's Avatar
Revise Test
I should make a revision to the little test method I mentioned earlier...
Rather than starting low and working up, start at the max pressure listed on the sidewall and work down. You certainly won't burn up the correct type tire for your trailer at max pressure. So start there, then back it down in small increments.
It'd be neat to see a chart that somebody could put together on this. I'd be curious to see the relationship between pressure and temperature. Also be good to figure out some way to tell how rough the trailer is riding at each pressure.
To do this right would take some time. You measure your pressure with the tire cold. The air expands as the tire warms up, so that the 65psi you put in when the tire was cold may be more like 70psi when it's warm. You'd then need to let them cool down again before backing it down to say 55psi, which may wind up being more like 60psi once the tires warm up.
Have to compare apples to apples.
Old 12-30-2005, 01:53 PM   #22
_
hi jim and others
seems i mentioned the temp issue in post 3 of this thread and starting hi then going lower.......see "tinkering". i do have a guage and have done this exercise on my car at the track and on the truck while towing. don't recall the numbers since i was also testing brake pads and rotor temps that day. i haven't done it on the trailer since i run 65psi and think its best.....i have measured tire temps at this pressure and the increase is small from ambient temps/road surface temps. my goal on the truck was to get similar temps on front compared to rear while pulling and hauling.
and jim if one plans to do the pressure measurements you suggest.....if the tires are properly inflated the pressure rise during use is very small....actually if the tires are underinflated there will be the biggest increases when warm.....so as odd as it seems the process is to run the questionably underinflated tires for a while and if warm pressure goes up much (>3-5psi) ADD air.....drive a bit and re measure.....as you approach the ideal psi the warm tires will cool some and the pressure differential will decrease.....of course this process is done will staying below the max psi on sidewall. yes check the cold numbers later too.
this is really a better exercise for properly finding t.v. tire pressures with/with out tow or load, or if, for some reason, running different brand/model tires on a multiaxle trailer or tandem/tag set up on a moho.....i used to do this to get the dualies tuned on my moho. turns out it is very common for the inside tire on a dual side setup to be underinflated.
but really this tangent has moved far from the original post......and the best advice has already been posted several times....
run sidewall max psi OR measure axle loads and use the brand chart and be sure the tire / rim load ratings are compatable. recheck frequently. that is all....
this is starting to read like one of those god awful threads on the yahoo site.....yikes!
cheers
2air'
Old 12-30-2005, 10:12 PM   #23
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A few numbers to think about
I read this thread and then went to a couple of tire sites and read some more. Tire pressure is a moving target. For every 10 degrees of temperture increase your tire pressure will increase around 1/2 PSI. For every 1000 feet of altitude your tire pressure will increase around 1/2 PSI. Changes in the weather will also change the tire pressure slightly. So, it's early morning at sea level and 30 degrees and you inflate your tires to 50 PSI. Later that day you are at 6000 feet elevation and it is 70 degrees. The tires will most likely be running around 90 degrees because of road friction. Your tire pressure is around 56 PSI. It is a little over a 10% increase. You could remove the heat factor from the equation if you fill your tires with nitrogen. The pressure change from altitude can not be removed. It's just like the bag of patato chips you take to the mountains and then it pops open!
Richard
Old 01-01-2006, 06:25 PM   #24
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
AZ Flycaster,
I don't get the 30 degrees in the above post. Please explain.
"So, it's early morning at sea level and 30 degrees and you inflate your tires to 50 PSI."
>>>>>>>>>>>Action
Old 01-01-2006, 08:15 PM   #25
Exeter , Rhode Island
I have never run my Marathons at max 65 psi. These tires have a load weight rating of 2540 lbs. per tire or 10,160 lbs for 4 tires. My 89 Excella has a GVWR of 8,300 lbs. I inflate to 58 psi.
Rob30044 is offline   Reply With Quote
Old 01-02-2006, 07:05 PM   #26
JimGolden's Avatar
yup, sho 'nuff
Yup, sho 'nuff you did mention that in post #3. Sorry I missed that. Least we're thinkin' on the same lines
I did email my buddy last week about this to see what temp his bike tires run at. Figured that'll give us an idea anyway.
Old 01-05-2006, 10:34 AM   #27
JimGolden's Avatar
temp
Got a reply from mechanic biker buddy. He says 105-110 degrees on his truck and 115-125 degrees on his bike with gooey sportbike soft compound rubber.
Old 01-05-2006, 05:34 PM   #28
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Tire pressure is one of the topics addressed by the RVSEF (RV Safety Education Foundation, Inc. 4575 Annette Court Merritt Island FL 32953). They are heavy into RV Safety. While at the Florida State Rally last year I had my tow vehicle and trailer weighed. They weigh each wheel and determine based on the tire manufacturers recommendations, the amount of pressure to carry on each ... AXLE ... .
Since most TV's and trailers are unbalanced side to side, (they should be within 10%) the pressure for the heaviest side on an axle is the pressure to be used on both ends of the axle.
It is true that running at too low a pressure will cause an early failure due to excessive flexing of the sidewalls which builds up heat and weakens the tire. Too high pressure will wear the tire in the center and actually decrease the amount of rubber on the road. The whole idea is to have the tire's designed footprint on the ground for best traction and tire performance, which is what we are all looking for. Which is why we should run the correct pressure for the load.
Another factor in tire failure is the age of the tire. Every tire has the date it was cast imprinted on the tire. For tires cast before 2000 it is a 3 digit number. the first two digits are the week it was cast and the last digit is the year. For tires cast in 2000 and later, the date is 4 digits. The first 2 are the week and the last two are the year. I just purchased a 1992 Cadillac with 18000 miles on it. The tires had a date of 202. Just for grins I took the car to several tire dealers and out of 5 tries only one could tell me the correct date which was week 20 of 1992!!! The tires were 12 years old!! I have replaced them since. The point of all this is that tires have a shelf life of 5 to 7 years. Beyond that the material in the tire has broken down to the point that failure is imminent. When you purchase tires, insist on seeing the cast date. If it is more than a year old, reject it and tell them why. Unless of course they want to knock 20% off the price of the tire...
In many cases where people experience tire failure they cant tell you how old the tire was or what pressure they carried. It is usually, "oh, just what the guy at the tire shop put in, I guess" or "gee the tires all looked good and the 1996 unit only had 30000 miles on it."
I have developed an Excel spreadsheet that when the design weights, ie GVW, GVAW, for the TV and trailer and the GCVW for the TV are entered plus the results of the TV and Trailer actual weights on each tire, calculates the correct pressure for each axle on the TV and Trailer, the tongue weight, and highlights any value that is out of spec. It also tells the remaining capacity at each weight point and for the TV and trailer.
It uses the tire data for that can be found on-line at any manufacturer website. The industry is standardized to the point that for the tire size and type, the weights and pressures are nearly the same.
One last thing. There is a difference between the sidewall construction of truck/passenger tires and trailer tires. You should use only tires that are prefixed with ST as in ST225/75R15.
The upshot of all this is... use the CORRECT tire pressure. It will extend the tire life, tread life and your life.
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
