Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-01-2015, 04:57 PM   #1
gitano
1997 33' Land Yacht
Livingston , Texas
Tire Pressure Conflict
The manual for my 1997 Airstream Land Yacht 33 states that the tire pressure should be 65PSI. The tag on the drivers door states that the pressure should be 80PSI. The manual and the tag appear to both be Airstream publications. Both give the tire size as 225/70R19.5. Which one is the correct pressure?
glistok is offline   Reply With Quote
Old 10-01-2015, 05:21 PM   #2
rhutson's Avatar
1980 25' International
Lorton , Virginia
Glistok,
What does the actual tire say? Use this to break the tie!
Good luck,
Rick
rhutson is offline   Reply With Quote
Old 10-01-2015, 05:27 PM   #3
Mission , Texas
Your AS has 19.5" wheels?
nrgtrakr is offline   Reply With Quote
Old 10-01-2015, 06:00 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I think this is a motorhome, not a trailer.
What do the sidewalls of the tire say?
Old 10-01-2015, 06:15 PM   #5
Retired.
. , At Large
When there is a conflict between the manual and a placard on the vehicle, go with the placard. It has the most current info as of time of production, and the manual may have been printed and revised.
Old 12-13-2015, 12:06 PM   #6
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Tire pressure
My placard on 2016 Flying Cloud 19' reads 65 PSI and cold pressure printed on the tires is 65 PSI (max I imagine). Is there any problem with pulling at 65 PSI assuming I keep my cargo load under the recommended level?
wareaglewalt is offline   Reply With Quote
conflict adding a radio Chatthayer Electrical - Systems, Generators, Batteries & Solar 9 01-24-2013 09:27 AM
Tire pressure label conflict Bambi75th Tires 15 07-30-2008 09:13 PM
Tire pressure conflict? Anniedog Tires 29 01-08-2006 05:47 PM
Conflict between OPD Valve & "Fuel Gauge" ? femuse LP Gas, Piping, Tanks & Regulators 0 04-22-2003 11:15 AM
