Old 03-29-2012, 03:36 PM   #1
roottonic
2001 19' Bambi
olathe , Kansas
tire pressure
Would like to know proper air pressure to keep in tires of my 2001 19 ft. Bambi. tires are ST 225-75R-15. Trailer is very lightly loaded. Thanks in advance.
roottonic is offline   Reply With Quote
Old 03-29-2012, 03:53 PM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
http://www.airstream.com/files/libra...fe9a57a9a8.pdf
Airstream publishes the manual for your trailer online at the link above. Page I-1 states that the correct tire pressure is 65 psi for a tire that has not been driven on that day (i.e. cold).
Cheers
Bruce
Bruce B is offline   Reply With Quote
Old 03-30-2012, 09:01 AM   #3
idmtman's Avatar
Worley , Idaho
The tire sidewall will indicate the load range. Likely load range D which, as indicated above, is 65 psi, cold. If it is a different load range, the sidewall will also specify the maximum pressure which is what I would use.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 03-30-2012, 09:27 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I follow the tire manufactor pressure recommendation.......IF I have the Airstream recommendation to the correct tires.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-30-2012, 09:32 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
I believe that I would rum the recommended maximum pressure of 65psi. With a single axle trailer, I would not want to chance tire failure from an underinflated tire becoming too hot.
Brian
SuEllyn & Brian McCabe
15" Tire dilemma 91Excella Tires 13 09-14-2012 09:31 PM
Pressure Regulator? LawChick Waste Systems, Tanks & Totes 16 09-11-2012 07:53 AM
Spare tire on the underbody? marshal1080 Repairing/Replacing Floor &/or Frame 13 05-16-2012 12:32 PM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Why bad tire wear? TankerIP Tires 15 03-15-2012 01:58 PM
