Old 08-01-2011, 06:30 PM   #1
TnVolGuy
trmiller's Avatar
1983 31' Excella
Cordova , Tennessee
Send a message via Skype™ to trmiller
Tire pressure
We have a 1983 Excella 31 ft that we purchased last August. I right away put new trailer tires on the trailer. The dealer put 45 psi in the tires. The tires are 700x15LT load range D. Now the tires say max psi 60 lbs. I've pulled our AS at least 1500 miles since purchase. I did notice a little sway with 18 wheelers until I brought the tire pressure up to 58 lbs psi in each tire this last trip of about 500 miles. It just pulled much better. So the plate on the AS says 45 psi. The tires say 60 psi. I know at 58 lbs psi and this heat they are gauging out at about 63-64 lbs psi. So anyone been thru this before and what psi would you recommend based on what I've said. Wantvto keep this AS jewel safe.
trmiller is offline   Reply With Quote
Old 08-01-2011, 06:47 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Just what I do.....as the road temp rises rest pressure drops. Usually ck pressures and temp at every rest stop.
Normal pressures 60psi cold.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-01-2011, 07:05 PM   #3
TnVolGuy
trmiller's Avatar
1983 31' Excella
Cordova , Tennessee
So you run yours @ 60 psi year around ?
Old 08-01-2011, 07:24 PM   #4
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
Usually put 55lbs in my tires. Have a tire pressure monitoring system (tpms) on the airstream tires so I can keep track of the pressure going down the road. When the tires get warmed up they generally stay around 60/61. The tpms is well worth the cost.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 08-01-2011, 07:43 PM   #5
Thumbs up
Yep......1/2 in the basement. (take 'em off in Winter)
PFC
"Tahawus"
RLC
John Prine
Old 08-01-2011, 10:52 PM   #6
1975 29' Ambassador
Reno , Nevada
45 is for load range C tires.
Always safest to run the tires at max sidewall pressure. Ride might be a bit rougher but the risk is much less to err on the high side.
Bob has good advice: check tire and hub temperatures when you stop for a break. They should run 120F or under depending upon conditions. If they run hot, add air.
Old 08-02-2011, 04:55 AM   #7
richinny's Avatar
2011 34' Classic
this thread has some discussion about tire pressures:
http://www.airforums.com/forums/f438...hon-67407.html
Ricky
Old 08-02-2011, 07:15 AM   #8
I agree that tires particularly LT tires should be run at maximum pressure.
A multi axle trailer doesn't turn the same way as a car. The sidewall is flexed when the wheel pivots. Maximum pressure diminishes the flex limiting the stress on the tire.
handn is offline   Reply With Quote
Old 08-02-2011, 10:00 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'm going to disagree with the tires being inflated to max. If they are overinflated, the same issue that occurs with car tires would occur with trailer tires - namely, the center bulging, meaning reduced traction and increased wear. Inflate the tires to what Airstream recommends. For our trailer, the recommended pressure is 50 PSI. You can go a couple PSI above that (5, maybe even 10) without a major problem. More info from Carlisle tires here (PDF) but other brands have similar information available too.
Ideally you'd get the trailer weighed and figure out how much weight is on each wheel, then set the pressure based on that. The link above has a chart that will help you do that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-02-2011, 11:17 AM   #10
How do we then rationalize these quotes from the above Carlisle link?
"maximum load range is attained only when the tire is set at it's maximum air pressure. There is no advantage to taking air out of the tire."
"The above table DOES NOT endorse the reduction of air pressure. Carlisle Tire & Wheel only recommends and only warrants tires maintained @ the max air pressure while in service."
I see no advantage in reducing tire pressures just because I am not carrying the tires max load.
FWIW...I consider max pressure for our D range to be 55-60 psi. and stay with-in that range.
As was noted in previous post, dual axle trailers do not track the same as your TV and the sidewalls must withstand higher stress.
I believe most failures are caused because of damage caused by heat/under-inflation.
my 2cents
PFC
"Tahawus"
RLC
John Prine
Old 08-02-2011, 11:54 AM   #11
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
You aren't really saying that as the road temp increases and therefore the tire pressure drops?????..............Perhaps "rest" pressure has some meaning that I am not familiar with. In my experience as the heat of the day increases the heat of the road surface that the pressure of the tire and temperature of the tire itself, rises accordingly.
For me, I use a tire presssure monitor system on the truck and trailer. Am currently going on perhaps 7 weeks on the road with 2 situations where the system totally saved in one case a tire itself, and the other damage to the trailer wheel well................WORTH THE EXPENSE.
After replacing a blowout in St. George, Utah, where the tech demanded that we up all the trailer tires to the highest recommended on the sidewall..........We had been running 60 psi but now upped it to 65.......
It does run straight and true at 60 psi and now at 65. At 50 psi I get LOTS of sway from trucks etc..................
As far as the comment about tire wear by high inflation. Have had this unit for going on 12 years and have yet to wear out tire one. As is the situation with most of us.......Instead the 3 to 4 year replacement issue raises it's head instead of the tire being worn out..............
YOU are familiar with the concept of replacing the tire at 3 or 4 years?????????????????????
God bless...............Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 08-02-2011, 12:29 PM   #12
Realizing that max pressure on the sidewall is done cold.
My bad....cold=rest.
I do adjust pressures to compensate for the higher tire temp. I usually start out a trip at 55psi and adjust if needed. On last years desert trip the "adjusted" pressures resulted in a low cold pressure.
if YOU was directed at ME......YES!
PFC
"Tahawus"
RLC
John Prine
Old 08-02-2011, 01:42 PM   #13
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Ignore the plate and follow the tire. The air pressure depends on the load range and the weight each tire is carrying. I have Goodyear Marathons Load Range D and I run them at 70 PSI. The side wall says 65 Max. However, Goodyear has a supplemental document that says you can at higher pressures. If I run them at 65 they wear as if under inflated. That means they are running hotter than they should.
Michelle TAC MT-0
Sarah, Snowball
Old 08-02-2011, 02:43 PM   #14
TnVolGuy
trmiller's Avatar
1983 31' Excella
Cordova , Tennessee
Good information people! I appreciate all the advice and info. Everytime I stop I do check temp and pressure. And as stated earlier did find rather warm tires even in cooler weather at that 45 psi and when I increased to 60 psi they were much cooler and the trailer pulled better and a lot less sway from trucks. I pull very level if not more to nose with my Dodge 1500 Ram pickup quad cab. Probably back pressure back to or around 57-58 psi and see how it does. Can always adjust up if necessary. Always great info on this site..thanks
Tire Pressure Sensor??? pappy19 Tires 9 07-14-2011 02:39 PM
Tire Pressure for Denman Express 68Glbtrotter Tires 1 05-10-2011 03:21 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
