Old 08-05-2011, 10:35 AM   #43
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by polarlyse View Post
I have Maxxis tires on my AS and run at max pressure all the time. I have one with a slowwwww leak that I cannot find so
See ya on the road.
Check the valve core. In a lot of cases they are loose.
At the next tire change switch to steel valve stems. they are less likely to leak.
Michelle TAC MT-0
Sarah, Snowball
Old 08-05-2011, 10:45 AM   #44
tpi
Trabuco Canyon , California
I inflate to 55 PSI and reinflate when they drop to 50.
I tow at 55-60 MPH and try to avoid hottest part of the day.
tpi is offline   Reply With Quote
Old 08-05-2011, 08:15 PM   #45
2008 25' Classic
crystal lake , Illinois
My tire hero shot.
Cheers, Ron
ronster737 is offline   Reply With Quote
Old 08-06-2011, 01:41 PM   #46
HowieE's Avatar
Princeton , New Jersey
Images: 12
My fondest memory of my Marathon tires.
Not sure I can say this with respect to a large number of the Marathon failures that have been reported here but in my case I think the weaker side walls caused rim leaks on hard turns. My tri axle trailer puts a lot of stress on the front, and more importantly, rear axle during a tight turn. So much so the deflection is notifiable in the mirrors. Any shock to the tire while under this stress could cause a rim leak and reduce pressure below the critical point and thus heat build up.
Thus another reason why I now run E rated tires.
2004 Excursion 4x4
Old 08-06-2011, 04:09 PM   #47
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
See ya on the road.
My slow leak was that the tire was not sealed on the Al rim due to a spot of corrosion. Dealer took the tire off the rim, cleaned the rim with a wire brush, and put it back on. Worked fine.
Tire Pressure Sensor??? pappy19 Tires 9 07-14-2011 02:39 PM
Tire Pressure for Denman Express 68Glbtrotter Tires 1 05-10-2011 03:21 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
