03-26-2009, 10:29 AM
1967 17' Caravel
East Bernard
Tire Pressure 67' 17ft Caravel
What is the correct tire pressure for I believe they are 205/75/15 trailer load tires for a 17'ft 1967 Caravel. I think they are 6ply Load C tires
Steven
"he who dies with the most toys wins"
03-26-2009, 10:53 AM
Princeton
, New Jersey
A 205 75 15 range C is limited to a max load of 1820 lbs per tire at 50 lbs.
Weigh your trailer and check that weight against the inflation chart.
http://www.goodyear.com/truck/pdf/da...dInflation.pdf
You may want to move up to a load range D if your are a single axle and tend to travel at higher speeds.
2004 Excursion 4x4
03-26-2009, 11:22 AM
1967 17' Caravel
East Bernard
I believe that trailer has a dry weight of roughly 2200 lbs.
Steven
03-26-2009, 11:38 AM
Princeton
, New Jersey
If you figure your loaded weight is 2700 lbs. that would be 30 to 35 lbs.
2004 Excursion 4x4
03-26-2009, 11:50 AM
1967 22' Safari
1960 Caravel
Edmonds
Hi Steven, This may help you.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
03-26-2009, 01:57 PM
Silverleeper,
Do you have this same image for a 1967 Globetrotter???
03-26-2009, 02:27 PM
1967 22' Safari
1960 Caravel
Edmonds
Originally Posted by toddster
Silverleeper,
Yes!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-26-2009, 04:35 PM
1967 17' Caravel
East Bernard
thanks for the pic...........I recognize it, comes right out of the original 67' owners manual I have for it
Steven
03-26-2009, 04:38 PM
1967 17' Caravel
East Bernard
hey toddster..........i'm digging that flag pole set up you got, might have to create me one of them.
Steven
