Old 03-26-2009, 10:29 AM   #1
1967-Caravel's Avatar
1967 17' Caravel
East Bernard , Texas
Tire Pressure 67' 17ft Caravel
What is the correct tire pressure for I believe they are 205/75/15 trailer load tires for a 17'ft 1967 Caravel. I think they are 6ply Load C tires
Steven
"he who dies with the most toys wins"
1967-Caravel is offline   Reply With Quote
Old 03-26-2009, 10:53 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
A 205 75 15 range C is limited to a max load of 1820 lbs per tire at 50 lbs.
Weigh your trailer and check that weight against the inflation chart.
http://www.goodyear.com/truck/pdf/da...dInflation.pdf
You may want to move up to a load range D if your are a single axle and tend to travel at higher speeds.
2004 Excursion 4x4
Old 03-26-2009, 11:22 AM   #3
1967 17' Caravel
I believe that trailer has a dry weight of roughly 2200 lbs.
Steven
Old 03-26-2009, 11:38 AM   #4
HowieE's Avatar
Images: 12
If you figure your loaded weight is 2700 lbs. that would be 30 to 35 lbs.
2004 Excursion 4x4
Old 03-26-2009, 11:50 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Steven, This may help you.
Name:	Airstream manual 15a.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-26-2009, 01:57 PM   #6
toddster's Avatar
1967 20' Globetrotter
Campbell , California
Silverleeper,
Do you have this same image for a 1967 Globetrotter???
toddster is offline   Reply With Quote
Old 03-26-2009, 02:27 PM   #7
1967 22' Safari
1960 Caravel
Images: 8
Originally Posted by toddster View Post
Silverleeper,
Yes!
Name:	Airstream manual 15bb.jpg
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-26-2009, 04:35 PM   #8
1967 17' Caravel
thanks for the pic...........I recognize it, comes right out of the original 67' owners manual I have for it
Steven
Old 03-26-2009, 04:38 PM   #9
1967 17' Caravel
hey toddster..........i'm digging that flag pole set up you got, might have to create me one of them.
Steven
Old 03-26-2009, 05:24 PM   #10
toddster's Avatar
Get in touch with Rob from the VAP. I purchased my 5 pole holder from him and have been EXTREMELY satisfied.
http://www.airforums.com/forums/memb...dzoe-4943.html
caravel
67' Caravel Dump Valve Replacement 18706 1967-Caravel Waste Systems, Tanks & Totes 17 04-11-2009 11:14 PM
Black water backup in shower or not 67' Caravel 1967-Caravel Waste Systems, Tanks & Totes 12 03-24-2009 10:27 PM
Squirrel blocker in 67' Caravel 1967-Caravel Winterizing, Storage, Carports & Covers 6 02-26-2009 06:42 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
67' Caravel top clearance lights (don't work) 1967-Caravel Lights - Interior & Exterior 10 01-31-2007 10:46 AM
