Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-13-2006, 05:21 PM   #1
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Michigan , The Great Lakes State
Tire pressure
We are planing a long trip with our 65 Caravel and would like to know what tire pressure I should run with, my tires are Goodyear's ST215 75R14, I presently have them set to 50 lbs..........thanks
toastie is offline   Reply With Quote
Old 10-13-2006, 05:43 PM   #2
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Looks like all the 14" tires are Load Range C and rated for max inflation of 50psi.
http://www.tirerack.com/tires/Spec.j...arathon+Radial
I'd run them at 48-50psi measured cold. With anything at all in the trailer you're pushing the limits of the tire.
bhayden is offline   Reply With Quote
Old 10-13-2006, 05:48 PM   #3
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
Randy
www.bestconverter.com
rvtirepressure.com
Old 10-13-2006, 06:16 PM   #4
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Really, pushing the limit? Please explain. I have 15" Marathons on my 66 Caravel - ST225 75/R15 rated at 2250lbs each. The new axle from Inland RV I will be installing on Tuesday is rated for 3000lbs. Two tires = 4500lbs of carrying capacity, well in excess for this trailer. Please let me know what I am calculating wrong. I will be very interested as I plan on staying with the "C" rated Marathons from now on. Almot impossible to find a name brand "D" rated around here. Just spent the better part of today looking and it would be 6 weeks for a delivery.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 10-13-2006, 06:37 PM   #5
bhayden's Avatar
Your using 15" tires. They have a higher rating than the 14" tires toastie reported having. For the 14" tires the load limit is closer to 1800# each. I'm making the assumtion that dry weight on the Caravel is just shy of 3,000# so figure ~500# or so of "stuff" and you're getting close enough to the rated limit that it seems prudent to get all the load carrying capacity possible from the tires by inflating to max psi.
-Bernie
Toastie ST215 75R14 = 1870 per tire or 3740 total capacity
Clancy_boy ST225 75/R15 = 2150 per tire or 4300 total capacity
The 15" tires give you a much more comforable margin.
Old 10-13-2006, 06:44 PM   #6
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Whew, I was hoping that I didn't goof, you are right - the 15" have a higher rating. May not be original to a 66 Caravel but that's what was on her when I got her. Bought 3 new rims to go along with the new axle. I will do the complete running gear change on Tuesday. Did't want any errors in my calculations to mess things up.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 10-13-2006, 06:53 PM   #7
Profile:  1979 31' Excella 500
Hrold , Washington
Tire pressure
I always run the max on the side wall for fuel ecconomy reasons and I dont want to heat up the side walls. It also aids in manuvers say you have to take evasive action to get out of trouble. I also check tire temp when I stop to get fuel simply with my hand warm is normal.
mustang is offline   Reply With Quote
Old 10-13-2006, 09:00 PM   #8
toastie's Avatar
1955 22' Safari
-Bernie
Thanks very much, I will run 48 to 50 psi, the reason for the 14" tires instead of the 15" tires is that airstream put on a new axile and when they installed the shocks they installed to close to the 15" tire's and when on a trip
it blew one on the tires, so instead of changing the shocks airtream put on brand new 14" tires with new airstream cast wheels, this is according to the owner that I bought the trailer from, just a heads up........
Old 10-14-2006, 02:47 AM   #9
Profile:  1992 34' Limited
Falls Church , Virginia
Heat in a tire will .....
Hello all -
In the voluminous reading I have done here and elsewhere about tires has lead me to beleive that sidewall flex is the sure death of a tire.
Sidewall flex of any source. The post primary source is underinflation, then over loading.
Having the righ ttire for the right application is CRITICAL.
Checking inflations/ temps at EVERY stop is a cheap way to know what is happening with your rubber.
Laser temp guages work Awesome to check both the tires and the hubs with no dirty hands - all in under 5 seceonds a wheel/tire. Compare over a trip to find the normal operating range. Anything out of whack, and if you don't check/change/correct..... you WILL have a blowout!!!!
Inflation check in AM (before heading out) and in the PM (when it's parked) will also add info to the situation.
Even having 1 tire go down - not even flat! - will add HUGE stress to any other remaining tires on that side. Be vigilant!!! Blowouts can cause serious wrecks, and at the very least be a HUGE pain in the *ss, or can even cause serious Checkbook depletion when those panels have to be replaced!!!!
Get good tools to keep yourself up on all that is happening with your rubber, your hubs and be sure to keep inflations even and consistant. All will be well with the world if you do this! Trust, me I know!!!!!!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 10-14-2006, 09:35 AM   #10
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
SilverToy, I admire your resolve and commitment to monitoring your tires for safety sake! Frankly, I'm too damned lazy to check my tires at every stop. Checking the tires four or five times a day is just way more than I want to buy into. When I set out to solve my trailer tire problems the sole purpose was to get tires which would give me the peace of mind, confidence and durability of the very fine tires I was using on my TV (Michelin LTX M/S).
On my tow vehicle, I check my tires before leaving on a trip, and a few times during a month long trip, and when I get home. When I'm home, I visually check them every couple of days and actually get the tire guage out every couple months. This is what I wanted for my trailer tires and this is what I got with the BF Goodrich Commercial T/A's. You can read all about it in the thread Tires....Tires....Tires. These tires are simply in a class way way above the Goodyear Marathons they replaced. I've towed our 25' Excella nearly 22,000 miles on them to date and their performance has been exemplary in every way. It looks like they will easily go another 50,000 miles. I have to chuckle to myself when I read posts where people say the life expectancy of Marathons is 6,000 to 12,000 miles (and that is with constant monitoring). Instead of constantly looking in the rear view mirror to see if the trailer is having tire problems, I'm watching the road ahead and enjoying the scenery.
Again, I admire your vigilance, really! I wish I could find a way to motivate myself to that level of performance. Seems like the older I get, the lazier I get.
2002 Toyota Tundra
Not that Bob Thompson, the other Bob Thompson!
Bob Thompson is offline   Reply With Quote
Old 10-14-2006, 09:59 AM   #11
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Bob, I am somewhere between you and Silver toy. I do check all my tires before every trip. When I stop I give the tires a kick to make sure that one is not soft and I check for overheating (with my hand).
I have the same tires on my Tundra that you have. What a difference from the originals. I looked at a few sites for more infor on your TT tires, but can not find them in a 15" wheel. What size are you running on your trailer?
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-14-2006, 10:01 AM   #12
'97 Excella 25
Images: 60
I've changed to 16" wheels. The BF Goodrich Commercial T/A's come in 16" and up sizes.
2002 Toyota Tundra
Old 10-14-2006, 11:10 AM   #13
Nye Thatcher's Avatar
Profile:
I have found that if I weigh my rig fully loaded,tanks full, and call the tire company, I don't have to guess. If you are going to a tire with a heavier load, be sure your wheels are designed to take that load. This spec. is stamped inside the wheel. I ran into this problem and had to go to split rims. This was not on an Airstream. I also stay with tires designed for travel trailers. The companies who make travel trailer tires spend a considerable amount of research on this.
Just a couple of thoughts to kick around. Good luck.
Nye
Nye Thatcher is offline   Reply With Quote
Old 10-14-2006, 12:34 PM   #14
'97 Excella 25
Images: 60
BF Goodrich approves their Commercial T/A's for all positions including trailer use. This is easy to confirm. Just call 877-788-8899 during business hours and ask for Customer Service.
2002 Toyota Tundra
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 01:31 PM
dual wheel tire pressure jpurdy Tires 2 10-15-2006 12:03 AM
Tire Pressure TBYRNE Tires 11 08-09-2002 10:04 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 07:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 02:44 PM
