Old 09-23-2015, 08:39 AM   #1
2004 22' Interstate
Collins , Mississippi
Tire Pressure 2005 Interstate
What pressure should the tires be for best comfort ride for a 2005 Airstream Interstate Sprinter. I have new Firestones 225/75/R16
The panel on the front seat says 55 Front and 80 Rear. Rides pretty rough
eavesron is offline   Reply With Quote
Old 09-23-2015, 12:10 PM   #2
Lily&Me's Avatar
Normal , Illinois
I would check with whoever installed your tires.
Enjoy your Interstate.
Maggie
Old 09-24-2015, 08:44 AM   #3
Berkel-Enschot , Noord-Brabant
I am able to calculate it with use of my made spreadsheet.
In this I use an even saver formula then the European tyre-makers use, wich on its turn is saver then the American tire-makers use.
I also add a reserve for maximum reserve with still acceptable comfort and gripp.
But need more details, and those are next.
From Vehicle ( I asume motorhome because of the comfort you want, but correct me if I am wrong).
Weights on seperate ends if loaded the way you use it, so with persons and loads in it.
Configuration = number of axles rear and number of tires on the road.
Speed you wont go over for even a minute in your use.
From tires next:
Maximum load of tires or loadindexes. for single and dual.
At pressure or loadrange ( probably LR D).
Maximum allowed speed of tires , mostly give as letter, N is up to 140km/86m/h and Q and higher use 160km/99m/h as speed for wich maximum load is calculated.
Give that and I will give picture of my filled in spreadsheet with some more information.
Will give a highest pressure to fill with still comfort and gripp.
But also a lowest pressure for the maximum speed you give at wich tires still are save , so wont get to hot and damage by driving that speed.
Greatings from a Dutch Pigheaded self-declaired tirepressure-specialist.
jadatis is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Optimal Tire pressure for 2014 Interstate? ATE123 Sprinter and B-van Forum 16 06-24-2015 01:10 PM
Installing Tire Pressure Monitor System in Airsream Interstate jerhofer Sprinter and B-van Forum 18 02-15-2015 11:18 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
