Old 07-21-2015, 08:28 AM   #1
2016 25' Flying Cloud
Celebration , Florida
tire pressure
Just wanting to know what you all use to keep air current in tires of AS and TV while on the road.
just took delivery 6/30/2105 of 25ft FC, excited and happy!
Do you use generator or compressor and if so which is preferred?
Have not seen anything regarding this on forum.
trigal is offline   Reply With Quote
Old 07-21-2015, 08:31 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have a couple of air compressors, a small DC unit and a 3 gallon oil less light weight unit. Both are from Harbor Freight.
MICHAEL
Old 07-21-2015, 09:18 AM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I use this: http://mobile.viaircorp.com/#2664
Love it. Forum member Bob Cross taught me a little hack to connect to my truck via the 7-pin connector for 12v power. Works great - quick to top off a few pounds on truck and trailer tires.
SteveSueMac is online now   Reply With Quote
Old 07-22-2015, 06:00 AM   #4
Berkel-Enschot , Noord-Brabant
I use a bicycle handpump with manometer ( or what you call it , I am from Holland, the bycycle country).
Its only to fill a view psi so wont take to long.
the large part when totally empty , you then do at a tank station , and inacuracy is then not such a bic issue.
Those handpumps are pretty accurate , a race bycycle tire needs also up to 120 psi, and these pumps are more stable to handle then a footpump.
Mostly adapters for car tires are included with those pumps.
But dont go for the cheapest, quality has its price.
Sorry if pump is not the right word, correct me then.
jadatis is offline   Reply With Quote
Old 07-22-2015, 06:07 AM   #5
z , North Carolina
Not the Best Thing
But it does the job. I have found too many gas stations have set the pressure limit to 50-55lbs at their air pump. That helps me not! Bought this off of Amazon. It's not too pricey, and not too cheap. A good "middle of the road" item that comes with its own carrying case.
http://www.amazon.com/gp/product/B00...ilpage_o05_s00
Sea ya down the road,
Gavin
FishinHatteras is offline   Reply With Quote
Old 07-22-2015, 08:01 AM   #6
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Originally Posted by SteveSueMac View Post
I use this: Mobile Site Preview
couldn't get any info off that site. It apparently is for telephones.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 07-22-2015, 08:59 AM   #7
W , New England
Sorry - Google "Viair 450-p" from your desktop.
Old 07-22-2015, 09:18 AM   #8
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I also carry a bicycle pump.
SSquared is offline   Reply With Quote
Old 08-01-2015, 05:52 PM   #9
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
If you buy a pump, be sure to get an oil less pump. I use mine to blow out water lines for winterization and don't want to put oil in my water lines. I carry a small 120 V air compressor in the truck. Great for topping off tires and blowing out water lines.
Airstream12557 is offline   Reply With Quote
Old 08-01-2015, 06:04 PM   #10
2016 30' Classic
Erie , Colorado
Viari 400P-RV Amazon.com: Viair 40047 400P-RV Automatic Portable Compressor Kit: Automotive
450P is a beefier version with a higher price.
RV versions include extension hose. Bullet proof and just does the job. Not sure I would want to run it from the 7 pin connector. Pulls a bunch of power if you need the pressure. 30amps max. Way over the limit of the 7 pin connector.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
