01-07-2007, 08:35 PM
1964 22' Safari
SACRAMENTO
tire mount
Where's the best place to mount the spare tire for our Safari?..we have been taking it w/our TV..what's the best way to mount it?
01-07-2007, 08:44 PM
1979 23' Safari
1954 29' Liner
Orange
Underneath the front of the body, between the frame rails.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
01-07-2007, 08:45 PM
1964 22' Safari
SACRAMENTO
Bill, would that be kind of low underneath?
01-07-2007, 08:55 PM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
Hey Paula, How about a Continental Kit on the back of the AS. And when we are all checking it out at the next Forum Rally you can serve us some of that wonderful avatar pie you're showing off!!!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
01-07-2007, 08:59 PM
1964 22' Safari
SACRAMENTO
Tim,
What is a Continental Kit?..I still haven't decided yet on the potluck item..you'll be surprised, so will I!!!
01-07-2007, 09:02 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
tire mount
The usual recommendation is to avoid spare tire mounts on the rear bumper. My coach had one for nearly 35 years, but was removed as part of repairs for rear end separation. The rear mounted spare tire carrier was identified as the proximate cause for much of the separation on my coach; and there has been no evidence of the separation problem redeveloping in the ten years since the repairs were made.
On a modern coach, I would go with the factory mount that places the spare below the front window between the frame members. My plan is to try to have one of the factory style behind the LP tank mounts fabricated for the spare on my Overlander as I, too am tired of the necessity of dragging the spare into or out of my tow vehicle.
Good luck with your research!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
remember when we were kids- some of the T-Birds had the tire hanging off the back bumber- thats a Conny Kit. OH gee you cannot do that on a AS, how bout the pie anyhooo.
www.popasmoke.com
YETI ( 65 Quart )
01-07-2007, 09:04 PM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
My spare is mounted up front under the gaucho
www.popasmoke.com
YETI ( 65 Quart )
01-07-2007, 10:17 PM
1979 23' Safari
1954 29' Liner
Orange
You remove the belly pan and insulation, the tire is up against the floor and sticks down the difference between the depth of the frame and the width of the tire. That is what I am doing for a spare tire mount on the Liner.
Bill
01-07-2007, 10:18 PM
1979 23' Safari
1954 29' Liner
Orange
It was also used on several models of the Lincoln and a fake continental kit is part of the Mark series.
Bill
01-08-2007, 09:06 AM
1993 34' Excella
Estancia
, New Mexico
If you have tandem axles Airstream says you can tow on 3 wheels. A friend of mine had a blowout and lost a wheel and drove on the 3 wheels with no apparent damage done.
01-08-2007, 10:21 AM
1978 24' Argosy 24
Woodinville
Towing on three wheels is an emergency. I'd only want to count on that for a short distance (like next off ramp) or if you have two flats. For instance you get a flat and then fine the spare is also flat. Remember that it you ran over something that caused a flat there's a good chance the other tire hit it too.
Besides the separation issue the spare, a fairly heavy object mounted at the extrem rear is about the worst thing possible for weight distribution. It might also be in the way of your electrical and dump facilities.
Cutting the belly pan and removing floor insulation seems like a bad idea for my use of the trailer. The belly pan helps keep heat in, water out and remember; aerodynamics under the coach are as important as top side. Besides that a spare out of site is out of mind and, for me anyway a sure recipe for not checking the air pressure regularly. For me the decreased ground clearance makes it a non-starter. Plus if you've owned a vehicle that neatly tucks the spare up into a cubby hole under the frame you know what a hassle it is to get in and out even under ideal conditions. Try it at night along the shoulder in the rain!
I really like the between the frame and the propane tanks location. My tanks are just a hair too close to the body to squeeze in the tire but I doubt that's a huge job to remedy. Who makes a kit, even better one that includes a polished tire cover, for the front?
-Bernie
01-08-2007, 10:30 AM
1967 22' Safari
Santa Barbara
Tips for front tire mounting
We have a 22ft 67 Safari (single axle.) We want to mount our spare tire on the front, behind the tanks. Does anyone have a picture of their mount? My husband can weld so we're planning to make the mount ourselves. Any tips out there?
Meredith hey you, get off of my flying cloud
01-08-2007, 11:45 AM
1964 22' Safari
SACRAMENTO
I think we're moving toward putting the spare somewhere sitting between the front of the Safari and behind the 2 propane tanks..looking for some kind of bracket/support setup..
02-02-2007, 10:08 AM
1970 31' Sovereign
Rogue River
, Oregon
Spare tire
Here is another way to mount a tire under the front. I got a spare drop down winch at a local u-pullit wrecking yard and mounted it across the frame. I welded a short 3/4" pipe with a old 1/2" drive socket in the end and drilled a hole in the front of the trailer. Now I just use a 1/2" drive ratchet to lower it to the ground. I do plan on putting a safety cable under the tire because I think it would be better than trusting just the cable.
02-02-2007, 10:44 AM
1964 22' Safari
SACRAMENTO
Hi Geezer, thnx for your suggestion and pix ..how much clearance is there between the bottom of the spare tire and the ground?
02-02-2007, 11:15 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
You may find this post/thread helpful ~ Spare Tire Carrier
Shari
02-02-2007, 11:24 AM
1964 22' Safari
SACRAMENTO
Originally Posted by InsideOut
Hi Shari,
Thnx much for the link!..I will check it out for the possibilities!
02-02-2007, 12:53 PM
1970 31' Sovereign
Rogue River
, Oregon
codybear
I still have the trailer in a way that it is hard to tell. But it only hangs down below the frame about 3 1/2" so I do not think it will be a big deal that close to the hitch. We are just up the hill in the Shingle Springs area,maybe will wave as we pass someday. Dave
02-02-2007, 01:19 PM
1964 22' Safari
SACRAMENTO
Dave,
Thnx..what size is your spare?..you're not far from Sacramento at all!!!..if interested, there's all kinds of Airstreamforums rallies coming up; check out the 4 Corner, Malibu, and the Cassini Ranch rallies!
