Old 02-02-2007, 10:08 AM   #15
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
Spare tire
Here is another way to mount a tire under the front. I got a spare drop down winch at a local u-pullit wrecking yard and mounted it across the frame. I welded a short 3/4" pipe with a old 1/2" drive socket in the end and drilled a hole in the front of the trailer. Now I just use a 1/2" drive ratchet to lower it to the ground. I do plan on putting a safety cable under the tire because I think it would be better than trusting just the cable.
Name:	Spare tire_0000001.JPG
ID:	31724   Click image for larger version
Name:	Spare tire_0000002.JPG
Name:	Spare tire_0000003.JPG
geezernbabe is offline   Reply With Quote
Old 02-02-2007, 10:44 AM   #16
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
Hi Geezer, thnx for your suggestion and pix..how much clearance is there between the bottom of the spare tire and the ground?
codybear is offline   Reply With Quote
Old 02-02-2007, 11:15 AM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by codybear
I think we're moving toward putting the spare somewhere sitting between the front of the Safari and behind the 2 propane tanks..looking for some kind of bracket/support setup..
You may find this post/thread helpful ~ Spare Tire Carrier
Shari
Old 02-02-2007, 11:24 AM   #18
codybear's Avatar
1964 22' Safari
Images: 315
Shari
Hi Shari,
Thnx much for the link!..I will check it out for the possibilities!
Old 02-02-2007, 12:53 PM   #19
1970 31' Sovereign
codybear
I still have the trailer in a way that it is hard to tell. But it only hangs down below the frame about 3 1/2" so I do not think it will be a big deal that close to the hitch. We are just up the hill in the Shingle Springs area,maybe will wave as we pass someday. Dave
Old 02-02-2007, 01:19 PM   #20
codybear's Avatar
1964 22' Safari
Images: 315
Dave,
Thnx..what size is your spare?..you're not far from Sacramento at all!!!..if interested, there's all kinds of Airstreamforums rallies coming up; check out the 4 Corner, Malibu, and the Cassini Ranch rallies!
Old 02-03-2007, 12:28 PM   #21
1970 31' Sovereign
cody
Sorry it took so long to get the tire size. I was in the middle of painting the frame yesterday. It is a 700 15 standard tire that is on both of our trailers. The outside is about 7" from sidewall to sidewall and it is on a stock 6" rim. Let me know if you need any more info.
Old 02-03-2007, 02:16 PM   #22
codybear's Avatar
1964 22' Safari
Images: 315
thnx, geezer, I'll check w/my hubby..
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
