Old 07-23-2012, 05:14 PM   #1
billiards's Avatar
rochester , Minnesota
tire life = speed
about to replace tires on my a/s 2005 safari 25'.......at what speed do you folk pull you trailer and w/water tank full or empty.....thanks a bunch (i havent paid much attention to top speed and maybe thats some of my problem)
billiards is offline   Reply With Quote
Old 07-23-2012, 05:53 PM   #2
2000 25' Excella
Northern , California
Compared to many others, I'm a slowpoke. I tow between 55-60mph, and since we don't dry camp, I generally leave the water tank empty. For pit stops, a gallon jug works just fine.
Kamiak is offline   Reply With Quote
Old 07-23-2012, 05:54 PM   #3
2005 19' Safari
GLENDALE , AZ
I tow in the desert southwest (110+ degrees) on 16-inch wheels and load range E LT tires, inflated to 80 psi. While I drove at 75 mph briefly after switching to LT tires, we have returned to 55-60 mph to save fuel and to increase the safety margin in emergency situations. Our 19-foot Bambi is usually towed with a full fresh-water tank upon departure, and nearly full gray- and black-water tanks on return trips.
Old 07-23-2012, 05:56 PM   #4
dznf0g's Avatar
Oswego , Illinois
I run 60 - 63. Keep just enough water in the tank to use the toilet, wash up for lunch, etc. and water the dog. Gray always empty, black empty to 1/2 full.
-Rich-
Old 07-23-2012, 05:56 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I tow between 55-65 mph. My last trip I pulled a full fresh water tank (60 gallons) at 55 mph, which is the speed limit for vehicles pulling trailers in Illinois. I had two tires with broken belts upon arriving home. I had inspected the tires upon arrival at the camp ground and all was well. Fresh water tank was empty upon departure for home. Still drove 55 mph home. Only difference was the temps were about 10 degrees higher on the trip home. I get home and detect that the belts apparently started slipping somewhere on the trip home. No answer for me. Tires were well within their weight capacity and proper pressure during the tow with the full fresh water tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-23-2012, 06:36 PM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
55-65mph with an empty water tank. Many would say my set up wouldn't go any faster anyway, but I do it for economy and safety; oh, and the fact that the speed limit in Ontario is 100kmh (62mph in old money) and I'm a sucker for obeying the rules.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 07-23-2012, 06:38 PM   #7
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Billiards,
We tow our 27' FB at 55 - 60 (sometimes push to 63 on long runs) and pass slow trucks or traffic at a max of 70 then back to 55 - 60/63. We always start our trips with a full tank of fresh water and empty gray and black tanks.
Originally Posted by jcanavera View Post
.... I had two tires with broken belts upon arriving home. I had inspected the tires upon arrival at the camp ground and all was well. Fresh water tank was empty upon departure for home. Still drove 55 mph home. Only difference was the temps were about 10 degrees higher on the trip home. I get home and detect that the belts apparently started slipping somewhere on the trip home.....
Jack
Jack,
What are the signs of a broken belts? What should we be looking for?
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-23-2012, 06:43 PM   #8
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I haven't towed as much as many of the posters here but I do find the best speeds are between 55 and 65 mph. I have hit 70 mph once or twice and everything feels just fine but my fuel mileage just disappears above the mid 60's so I tend to keep it down there. The entire experience is just a whole lot more comfortable when you keep it on the slow side.....
Bruce
Bruce B is offline   Reply With Quote
Old 07-23-2012, 07:14 PM   #9
Scott J-24's Avatar
When I get impatient driving at slower speeds or stuck in traffic, I try to remember that it is the jurney not the destination.... (doesn't always work for me though....).
WBCCI #1215
Air #54601
Old 07-23-2012, 07:26 PM   #10
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Once I replaced the ST tires with LT, I became more flexible about speed. But usually tow between 65 and 70. Sometimes a bit faster if the speed limit and/or constabulary allow. Slower on narrow roads, mountain roads, high traffic situations or where I think I might need to stop quickly, etc. Once on an abandoned freeway, ran her up far in excess of speed limit to verify rock-solid no-sway towing. Now know I have a large margin for error, passing, etc.
Almost always boondock, so almost always leave home with full fresh water, unless it's winter or I'm headed for wintry climes. Try to return with empty gray and black tanks and then drain out the fresh water until next trip. I think that if the fresh tank is full (= no sloshing), the extra weight down low does good things for the center of gravity. Is that meaningful? Probably not, but every little bit helps. Just my $.02.
AirsDream is offline   Reply With Quote
Old 07-23-2012, 07:30 PM   #11
2000 25' Excella
Over the course of a 300-mile day that many people have said they travel, the difference in arrival time between 60 mph and 65 mph is a little over 20 minutes. Most of the time, that differential doesn't matter, and there's seems to be a real sensitivity to fuel consumption at speeds > 60mph.
Old 07-23-2012, 07:30 PM   #12
r carl's Avatar
Lin , Ne
Originally Posted by Scott J-24 View Post
Billiards,
Jack,
This is a bad one.
Old 07-23-2012, 07:55 PM   #13
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I'm comfortable at about 65mph on the highway, with D load rated GY Marathons at 60-65 lbs. Everything feels right at that speed, and the TV isn't working too hard. We leave with the water tank full, so we have "home" water, and black and grey empty. We always dump the b&g before leaving any campground.
robert claus is offline   Reply With Quote
Old 07-23-2012, 07:58 PM   #14
Scott J-24's Avatar
Originally Posted by r carl View Post
This is a bad one.
Carl,
Thanks, hope I never see that on my tires!
WBCCI #1215
Air #54601
