Old 02-16-2011, 07:32 AM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by A W Warn View Post
My opinion is if the rubber is not checked on the sidewalls, the tires have no visible cuts lumps or bumps, and the tread is good, then age of the tire is not an issue.
The thinking is recreational trailer tires sit more than they are used, so you can have an old tire with good tread. Tires deteriorate from the inside where you can't see it.
Old 02-16-2011, 09:52 AM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Like any tire thread you'll get plenty of opinions and few facts.
I will throw a few opinions into the mix for you to consider:
- I believe the 5/6 year timeline is extremely conservative
- Any tire will fail more rapidly at higher temperatures
- You may get more safety for your dollar with brake and hitch maintenance and upgrades than with tires
Old 02-27-2011, 11:06 AM   #17
HankO's Avatar
1997 28' Excella
Eden , Utah
A couple of my tires have some cracking starting to appear, but the tread is like new (probably less than 3000 miles on the tires). I think I will put tubes inside them to give extra support. I've done this with tires on my utility trailer and they lasted for several more years.
HankO is offline   Reply With Quote
Old 02-27-2011, 02:15 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The cost of new tires is a lot less then the amount of damage a failing tire can do to an Airstream.
Richard
On-axle tire and wheel balancing Jammer Wheels, Hubs & Bearings 8 02-16-2011 05:56 PM
Any good tire covers? hhendrix Tires 15 02-01-2011 02:43 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
