Old 10-07-2005, 02:09 PM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by Buttercup
O.K. - now this is one that I don't understand how it works. I'll have to look into it more.
Nice little piece about nitrogen there...
Buttercup,
In two words...centrifugal force...and FWIW my wife's uncle uses the same product on his big gravel trucks.
Aaron
WBCCI #XXXX AIR #2495
Old 10-07-2005, 07:50 PM   #16
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet
Back in the 70’s, when I was working Daytona & Sebring as pit crew with a IMSA Porsche team out of Ft. Lauderdale, I provisioned multiple Nitrogen tanks for air tool operation, being told that it was dryer and didn’t foul the air tools. Further, the Nitrogen is inert and would not support combustion – a requirement in the pits. Additionally, becuase nitrogen has a much more consistent rate of expansion and contraction compared to normal air, tire pressures were staying more consistent; as 65GT pointed out.
Race teams used to bring their own cylinders to each track and sometime in the 80s’ a company called Air Products, in the North East, began selling a service to the IMSA teams and supplied ‘rental’ tanks on site. This was cool because we didn’t have to ‘schlepp’ these bulky cylinders around. Now they are available at all the racing tracks, as Canoe Stream has pointed out.
It is a common accepted belief of professional truckers that tires fatigue and fail from oxidation. By using nitrogen, the oxygen content in normal air is not attacking the tire from within, and therefore the tire service life is extended. Apparently, the tire body (not the tread life) is extended, resulting in fewer failures.
Further, relative to the maintenance of air pressure over time, the truckers claim that the water content in air causes rust (iron oxide or aluminum hydroxide) within the wheels. This becomes powdered quite fine and becomes trapped on the seal of the valve stem when air pressure is checked.
Personally I use air (with water – oh well!) and utilize a metal stem cap with rubber seal, on all my tires.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 10-07-2005, 08:21 PM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
We too have used nitrogen on aircraft and race car tires. For my good old common garden variety truck, trailer, and tractor tires I use air from my shop compressor which has an inline filter to catch water on it....so I guess I am using dry air But come to think of it...the tractor tires have a calcium chloride solution in them... I really believe that using Nitrogen for normal day to day use is a bunch of hype and a sales pitch. Face it most of our AS tires are going to die of dry rot from UV exposure and non use long before anything else.
Aaron
Old 10-08-2005, 12:22 AM   #18
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
I swear I did a search on nitrogen and didn't find any meaningful threads.......sorry for the duplicate thread ! I also haven't been a member as long as some of you (that remembered the previous threads). I don't consider myself an autophile........I just drive the dang things.......and when I see a news story on something that may improve mileage and increase safety....I'm all ears! I wasn't thinking of putting nitrogen in my AS tires....but in my Tow Vehicle. I don't know how Costco rates for tire sales or quality of service because I've never bought my tires there. I agree it must be just a gimmick to boost their tire sales, which it probably did! I just wanted to find out if there was anything to this or not........I guess there isn't . Sooooooo, thanks for all your replies......you won't find me filling my tires with nitrogen!!
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 10-27-2005, 06:36 PM   #19
1984 31' Excella
Norfolk , Virginia
Images: 11
Nitrogen
The NAVY has been using dry nitrogen in their aircraft tires for at least 20 years now. This I know first hand. The reason is because of the more consistant tire pressure between hot(after landing and after takeoff) and cold. When you run 22 ply tires inflated to better than 300 psi, it can make a difference. Also the nitrogen retards the corrosion in the wheels themselves. Also important on a high performance aircraft. The tire manufacturers tell us that the air in the tire actually passes through the sidewall (thinest part of the tire). As it passes through, it causes the rubber compounds to oxidize, thus decreasing the life of the tire body itself. The moisture in the air in the tire expands when heated. The more heat, the more the pressure in the tire rises. This is not a factor in a farm tractor tire, (rarely driven over 25 MPH) but it very well could be in a GoodYear Marathon cold inflated to 65 PSI and then driven on a hot interstate in the summer time for hours on end.
Beginner is offline   Reply With Quote
Old 10-31-2005, 10:49 AM   #20
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Beginner,
The air you are breathing right now contains almost 75% nitrogen right now. Coupled with the less than 300 psi and less than 22 ply tires I have, I think I will stick with plain old air. This tends to simplify my life a bit. Course I only go about 65 tops on the freeway. And I have witnesses.
>>>>>>>>>>Action
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
