Old 03-13-2016, 07:07 AM   #43
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by SteveSueMac View Post
Let me see if I understand this concept correctly. My p-rated 15" Michelins have a max of 50 PSI. So let's say it's 70 degrees outside at 8:00 am and the trailer has been sitting overnight. I ensure the tires are at 50 PSI and start a long road trip.
By noon, it's 100 degrees outside so the ambient temp is +30. So I should expect about 3% of 50 PSI increase for each 10 degree rise in ambient - or a total of 4.5 PSI increase just due to the rise in ambient temperature, correct? .......
Correct.
.........And what then should I expect for the 4 hours of 65 mph towing? ......
No more than a 10% buildup! And that should occur within the first hour and a half.
...... Is that where your 10% window comes in to play ........
Yes
......... - and if so, is that on top of the increase for ambient? ........
Yes
........ In other words - if the PSI was 59.5 in this scenario where 4.5# was due to rise in ambient temp and 5# (or 10%) was due to travel friction - is that 19% total increase in PSI acceptable? ............
Yes, from the point of view that your starting psi was adequate.
........... Or is it dangerous because it's more than a total of 15% increase in PSI? .........
No, it is NOT dangerous, because the increase in pressure due to running was 10%.
Ya' see, the point of the test is to measure whether you have adequate load carrying capacity and by measuring the pressure build up, you are indirectly measuring that.
........ I ask because I've set my TPMS alarm to go off at 57 PSI thinking if I get over that 12-15% range I'm in trouble. Wondering if it's safe to set the alarm at 60 instead to account for both factors? ........
I think the alarm set at 57 would be OK, as what what would happen if the outside temperature dropped? If the alarm is going off because of the outside temperature increase, and you know that, then you can ignore the alarm. Personally, I'd rather have an alarm going off prematurely ratgher than too late!
......... I've usually seen almost exactly 10% increase in PSI and 30 degree temp above ambient no matter how cold or warm ambient actually is and no matter how many miles I drive - though maybe once or twice to 56 PSI on triple digit days....
It sounds like you've kind of answered your own question.
CapriRacer is offline   Reply With Quote
Old 03-13-2016, 07:21 AM   #44
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks CapriRacer! Very helpful. And that last bit was really just an observation on my part - not so much an answer to the question. Your response helped me understand more about the tolerances and test for load capacity. That 10% increase in PSI that I see usually happens within the first 60-90 minutes on the highway and remains there for the duration of the trip - though as noted, if triple digit weather is happening they can rise another pound.
Also liked your reason for keeping the alarm at 57. Makes sense to me and should I experience higher PSI in very hot weather (or, in temps that are 40-50 degrees higher than when I hit the road) I can relate that to the ideal gas law and not lose too much sleep over that. (Roger Goodell would do well to read this forum ... But I digress 😃🏈 ).
Thanks again - very helpful insights!
SteveSueMac is online now   Reply With Quote
Old 03-14-2016, 06:38 PM   #45
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by mike28 View Post
What is the proper inflation for the 16" Michelin tires on a dual axle trailer with a gross max weight of 9100 lbs? I get all kind of suggestions.
It's simple enough to avoid problems by using max sidewall pressure. It's not just in tight turns, but also in braking. The forward axle of the tandem winds up with the main load
It's the TV that takes more time to figure out, and that by using scale readings when hitched correctly. Correctly hitched is itself a topic. But it's also the only way to find INDIVIDUAL tire loads. The worst load on the axle would be the minimum (after road testing). The TV is what takes work, not the trailer.
Old 03-15-2016, 08:58 AM   #46
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If one has the individual weights of each tire, then one can look at the Michelin weight capacity versus tire pressure.
80psi 2,680 (E)
75psi 2,560
70psi 2,440
65psi 2,335 (D)
60psi 2,190
55psi 2,060
50psi 1,940 (C)
45psi 1,790
We figured 72.5 psi could be optimum with a extrapolated weight capacity of 2,500 pounds. We tend to make life easier and put in 75 psi.
Old 03-19-2016, 09:44 AM   #47
BlackAces's Avatar
Taylors , South Carolina
In the industry where all of your RV trailers were manufactured there are regulations the trailer manufacturer MUST follow. One of those regulations is unique to the trailer manufacturer, they are directed to set recommended cold tire inflation pressures for every trailer they build and certify. Those recommendations are going to be displayed on the federal certification label, tire placard and in the vehicle owner’s manual.
Tire industry standards - the rules used for consumers - are supported 100%.
Tire industry inflation charts are used by manufacturers to set recommended cold tire pressures. They are used by retailers/tire shops when installing replacement tires that use different charts than the OE tires use. They are not intended to be used to jack around tire inflation pressures where established recommendations have already been set. Unless, there is reserve inflation pressures above the recommended pressure values. Any pressures used below the established recommendations is considered under-inflation. Any pressures used above the maximum pressure molded into the tire’s sidewall is considered over-inflation. Any reserves in-between is there for the using.
Vehicle owner manuals may have optional pressures for vehicles that tow things. Automotive industry tire fitments must provide a percentage of load capacity reserves. Trailer tire fitments do not have that provision. For RV trailers there is seldom any wiggle room with inflation pressures and those needing extra load capacities are probably already over-weight. If you’re looking for a smoother ride I suggest you upgrade your suspensions. Fooling around with tire pressures on RV trailers is like asking for some time on the side of the road to change tires or waiting for someone that will.
Industry standard: Replacement tires need to have a load capacity equal to or greater than the OE tires, by inflation. The installer should inflate them to a pressure value equal to the load capacity of the OE tires. To take advantage of a stronger tire an inflation pressure allowing more load capacity than the OE tires will provide a relaxing amount of reserve load capacity. Auxiliary tire placards are allowed to be placed adjacent to the current placard. It should display the new tire size and recommended inflation pressure.
When you’re operating outside of the established norm you’re on your own - so to speak - and solely accountable for your actions. If retailer’s/tire shops offer different options make sure they are in writing and on the bill of sale. If they wont do that eye brows should go up.
Note: Inflating your tires to the load carried is a product of other regulations in the trucking industry (FMCSA) and has no place in the safety regulations (FMVSS) for RV trailers. FMCSA has no provision for recommended cold tire inflation pressures. Their results are strewn all across our country, on every major highway.
BlackAces
USN - RET - PDRL
DoD & SSA - RET
BlackAces is offline   Reply With Quote
Old 03-20-2016, 03:30 PM   #48
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I check all my tires before we go on a trip, and do a look see every time we stop,never had any problems....my big truck has 120 lbs cold , in the steer tires, after 500 miles on a hot day, when I checked them out of curiosity they will read having 132 lbs, never had any problems,why worry about it?...
Best dual tire inflation method TimsLegacy Airstream Motorhome Forums 3 09-19-2012 01:20 PM
Tire Presuure and inflation woodedareas Tires 4 11-12-2006 10:14 PM
Tire inflation with nitrogen jordandvm Tires 19 10-31-2005 10:49 AM
Air compressor for tire inflation? cammur Tires 11 10-27-2005 10:05 AM
Tire inflation pressure Tin Hut Tires 15 03-04-2005 05:12 AM
