Originally Posted by Melody Ranch
i use these...
is that a bias ply tire?
those might be fine for old beater trailers with leaf springs, funny plumbing and gas lighting...
but would not be a wise choice for the o.p.
NONE of these modern radial ply ST tires are 8 or 10 ply...
they're C or D or E rating which is comparable to 6 or 8 or 10 ply BIAS tires...
so the term used is "PLY RATING" for these newer tires.
they are assembled with 4-5 'layers'...
for example gyms are 2 steel plys, 2 polyester plys and a nylon belt/cap layer.
genuine BIAS ply tires are still available but would be a bad choice for almost ALL 'streams built in the last 30-40 years.
________
the 1985 25 footer would actually be FINE on C rated radial tires, unless it's been altered or OVER LOADED.
D rated (8 ply equivalent) are a FINE choice...
at 25 years of age the axles may be tired, hardened or in need of replacement...
more rubber bits to consider.
cheers
2air'
