Old 07-01-2008, 12:50 PM   #1
Newlyweds's Avatar
1975 25' Tradewind
Stoughton , Wisconsin
Tire Help
Hi Everyone,
I have a question about tires. Well it's not really my question it's my husbands. We have a 1975 25 ft Tradewind.
The tires we have on the trailer are 7.0 x15 but I think they are bias ply.....what size would you put on if you are going to get radial tires like good year marathons?
Any help would be greatly appreciated!
Thanks!
Newlyweds is offline   Reply With Quote
Old 07-01-2008, 01:00 PM   #2
Originally Posted by Newlyweds View Post
Hi Everyone,
Thanks!
ST 225/75 R15 load range "C"
Old 07-01-2008, 01:41 PM   #3
Newlyweds's Avatar
1975 25' Tradewind
Thank you sooooooo much for your help!
He was hoping that you would reply. Too bad your dealership wasn't in Wisconsin!
Thanks again
Old 07-02-2008, 01:33 PM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Load Range D
Thanks!
We like the Load Range D's. It has a stronger side wall and I hear over and over again that it helps in towing.
I was at the safty meeting for Spring Rally Reg. 3 in Raleigh NC and a couple of the members said they had new Loan range C's and took them off, for Load range D's
We have them on Sale.
Dan@LED4RV is offline   Reply With Quote
Old 07-02-2008, 05:27 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
This is what I've used on my 8,000-lb GVWR Silver Streak, tandem-axle:
Yokohama RY215 LT Load Range D, 15", 8-ply rating in 7.00 x 15 (7R-15):
Currently Available Prices and Sizes
They balanced well (less than 24-ozs per wheel/tire assembly) and exactly meet the load rating recommendation by the trailer manufacturer.
Despite the description given on the website above these are LT tires used for commercial vehicles. I run mine at the rated 65-psi.
The corporate site has a good description and picture plus specs:
Yokohama
Old 07-02-2008, 07:28 PM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
I am getting Yokohama RY 215 LT load range D next week. I have done a lot of research and this it the best I have found.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-02-2008, 09:35 PM   #7
Marvin
The size should be 225, not 215.
Old 07-02-2008, 10:30 PM   #8
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
Tires?
I am looking for new tires for my 63 Ambassador. It has 7.00-15 on it now any suggestions on what to replace them with? I have priced Trac Star "D's" . I thought radials we not good for travel trailers since they had soft sidewalls??? I thin I pulled a shoulder muscle trying to get the tires out of the wheel well, very tight!!!
63silver
63Silver is offline   Reply With Quote
Making tire changes SRW Tires 7 03-16-2008 05:35 AM
TV Tire Size campadk Tires 34 09-04-2006 09:44 PM
Tire ? Stream 1529 Tires 8 08-04-2006 10:55 AM
MH Tire presure? donnall Airstream Motorhome Forums 22 03-20-2004 08:03 PM
What is behind my tire? jkenny Axles 6 01-21-2004 01:21 PM
