09-05-2015, 06:50 AM
Northeastern
, Kentucky
Tire failure at 13 months
Had my first tire failure at about 55mph after being on the road for about 3 hours. My tires were installed just over a year ago and run at 60 psi (sidewall says max of 65psi). Fortunately a passing auto let me know otherwise I wouldn't have realized it until I slowed down, and no apparent damage to the trailer was done. Pics attached. Any tire experts able to tell what the cause might have been?
Also, when installing my spare I came to the conclusion that my manual pump is about worthless. I need to get one that runs on 12v, but I also like having manual pump [if it works and doesn't fall apart]. Any suggestions on a 12v and solid manual pump?
09-05-2015, 07:09 AM
z
, North Carolina
KYAirstream
Here's a good option for a 12v air compressor:
Amazon.com: Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor: Automotive
I won't comment on the tires, but I would certainly look at the date of manufacture when you bring them back to the dealer that put them on there.
Given the size of your rig, I would think you would be considering moving up to a
Michelin tire after this incident. You have better things to do than be stuck on the side of the road. I can't make out the brand of tire that was on there, but at least switch to another manufacturer if you are unable to move up to the Michelin's.
Failure after just one year, is un-acceptable for ANY tire.
Sea ya down the road,
Gavin
09-05-2015, 08:08 AM
Northeastern
, Kentucky
Thanks for the 12v recommendation. Agreed on the LT tire and was planning to do so, but was hoping to wait until next year.
It's a Mastertrack load range D with max load of 2540lbs, so 10,160 lbs for all four and my trailer weighs a MAX of 7500lbs fully loaded with everything imaginable. This trip we were probably at about 7,000lbs. So I thought weight wise I'd be fine with these tires to hold me over until I got new rims and tires next year. For my next set I was planning on going with load range D as well, since there seems to be an adequate margin per the numbers?
Date stamp says 1314, so I assume that's the 13th week of 2014, so around March. I purchased them in July or August 2014.
09-05-2015, 09:08 AM
z
, North Carolina
Yup
Load range D is certainly acceptable given your weight ratings. I have no previous dealings with MasterTrack. Never heard of them, to be honest. If you wanted to hold off on getting the Michelins, may I suggest a set of Maxxis tires to get you thru the end of this season at least. They are not that expensive, and are a pretty well made tire. I have had very good luck with this brand as a trailer tire. They also make a light truck series. They sure beat the heck out of a Goodyear Marathon, I can promise you that.
As to the 12v compressor, I purchased that same unit, and it's no speed demon in getting your tires inflated. For the roughly 60 dollar price tag, it works well, and stores easily in it's own bag. Sure helped me out several times on our trip out W this past May.
Good luck in your decision, and I'm sorry your trip was inconvenienced. I certainly would have stopped to help you out.
Gavin
09-05-2015, 09:23 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
What is the date code on the tire?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
09-05-2015, 10:12 AM
Mantua
, Ohio
See post 3
09-05-2015, 10:59 AM
2011 30' Flying Cloud
Arvada
I've had a lot of luck with a ViAir 90P portable compressor. Regarding tires, I used to under inflate my tires until I had a failure. Was told then that best thing to do it to run them at recommended max pressure - in my case 80lbs. They will run cooler and then are less prone to heat build up and failure. I also started using a tire pressure monitoring system. At $260.00 it is well worth it.
09-05-2015, 11:00 AM
2010 28' Flying Cloud
Lower Alabama
, USA
We have a couple of tire engineers here on the forums that I hope will comment. I sent them a heads up on this post and hope they will have time to comment.
First thing you likely will hear from both is to run full cold inflation pressure as indicated on the side wall.
Not sure that photos of a tire that was run flat for a distance will help. It is likely that the extensive damage you see occured after it lost air and likely is not indicative how it failed initially but I am no expert. Do you have any other photos the you could share?
From your post, I infer that you do not use a TPMS. What had been your maximum towing speed with these tires? Was this tire on the front or rear axle. Did the tread wear show excessive wear or failure? Was the tire punctured causing loss of air?
Hope our experts can chime in.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
09-05-2015, 11:18 AM
2007 28' Classic
Ivanhoe
, Virginia
Vi Air through
Amazon, around $100. Very quick, can use for higher pressures on the larger tires. My former Rv called for 80#, takes forever with the smaller compressors. Tire failure looks like tread separation, prob. Factory defect. Get St rated tires, not Lt. Lt is for light trucks, ride rougher. St is trailer rated, more sidewall flex and smoother ride. I have found Discount Tire to be the best all around retailer, nationwide, been Rving since 1973.
09-05-2015, 11:23 AM
2007 28' Classic
Ivanhoe
, Virginia
Alphonse makes a good point re: TPMS. Saves a lot of worry, worth the money. While I have always inflated to sidewall max., I am changing to factory recommendations on TV and Rv for better ride quality. 1 ton dually 4x4 is rough enough as it is.
09-05-2015, 11:26 AM
1967 26' Overlander
Spartanburg
, South Carolina
Here's another 2 cents. Not being familiar with your brand of tire I can't comment on it but a failure for no obvious reason is very odd. You didn't say what type of tire it is. I have been towing a 26' A/S for 27 years and I don't recommend anything less than an ST type tire, whoever the manufacturer is. I personally have run Goodyear Marathon ST's for 14 years now with no problems whatsoever. My fellow club members who run Maxxis have had similar experience. Both are available in load range D. The reason you want to run ST's is that when turning a tandem axle sharply, esp. when backing, large side wall stress occurs. ST's are designed to resist damage from those normal stresses. Last I heard, Michelin does not make an ST.
09-05-2015, 11:42 AM
2012 27' Flying Cloud
San Angelo
Were the rims from the time of trailer origin? They look in the photo like they have been around for awhile. Check to make sure you don't have a rim split. Had this happen long ago. Leak in the rim, tire goes done and pop! TPS systems are well worth the money I was convinced until recently that tire "blowouts" were mainly caused by running at too low a pressure. Recently I had a truck tire that was three years old (Goodyear- little tread wear and on the passenger side rear) blow out and the consensius of three different "tire experts" was that it shouldn't have happened BUT it was probably over pressured. On the other hand, I had a "tire expert" tell me Goodyear Marathons were a perfectly good tire. Go figure. On my truck tire, nobody could find any evidence of a puncture. (max pressure on the tire was listed as 80 and it was probably running at 87 ish.) Day was one of those 102F days and we were coming out of the New Mexico Mountains onto the west Texas flat land at about 65mph. By the way, the Good Sam guy that rescued us (3/4 ton truck tires are a bitch to change with the trailer connected using the provided toy jack) Checked all the tires, told us they were all too high and said the cold inflation should be about 6 lb. give or take under the max pressure rating. That normally results in the tire ending up running just at the max recommended inflation. Up to now, I've run the trailer tires at the max pressure given on the tire as the cold inflation pressure. Sort of causes a whole series of questions when you start out when it's in the 30's and you end up driving back when it's in the 90's.
I changed the trailer tires to Michelin's and went to 16 in rims a year or so ago. Truck tires will be changed over to Michelins before the late fall travel season. By the way, I have run Maxxis on two different trailers for several years with good luck. Just feel better with the Michelins
09-05-2015, 12:45 PM
1966 24' Tradewind
2005 22' Safari
Bastrop
Looks as if it went flat from a nail or something and was simply destroyed from being run flat . Been there , Done that .
09-05-2015, 01:02 PM
Ravenna
, Ohio
Run Low Flex failure
While many of the comments offer interesting observations and ask reasonable questions it is my considered opinion that what you have is a classic example of a "Run Low Flex Failure"
In your case you stopped just before the tire turned into either a two piece or three piece flex failure.
The key evidence is the nice circumferential nature of the damage. If you carefully feel along the edge of the break you will fins that some of the cords are hard and some appear to have simply vanished from the rubber in the sidewall leaving empty holes.
This is what happens to polyester when it gets near its melting point 350°F+
I have a number of posts on my blog RVTireSafety showing examples of tires with different degrees of this failure. One was captured from a video made by an AS owner.
At highway speed you can have this type of failure in less than 10 miles depending on the inflation in the tire.
You can loose air for a variety of reasons from the obvious cut or puncture or a leak of the valve core or a failure of the valve to completely seal in the hole of the wheel.
To often people don't change valves when they get new tires. or use a standard passenger tire valve that is only rated for a max of 65 psi when new. I note your valve is missing. Also remember that the rubber in the valve can "age-out" just as the rubber in the tire does.
To avoid this from occurring in the future I suggest that you use bolt in metal valves and get a TPMS that would warn you of a loss in air pressure. While nothing is 100% a TPMS on a metal valve stem is your best defense
09-05-2015, 01:09 PM
Ravenna
, Ohio
I would be careful with info from "Tire Experts". Just because someone may have driven a few hundred thousand miles on tires or mounted hundreds does not make them an expert in failure analysis.
I have never met anyone that works in a tire store that has had in-depth training in failed tire examination. This is a specialty much as a Medical Examiner is better at doing an autopsy and diagnosing what actually caused the death than even a brain surgeon. Different specialties have different skills.
Even in the design centers for large tire companies such as Bridgestone, Michelin and Goodyear there may be fewer than a dozen engineers worldwide that had their primary job responsibility of doing cut tire "autopsies".
09-05-2015, 01:23 PM
2013 27' FB Eddie Bauer
Salado
Having pulled and RV'd now for about three decades, there are two pieces of wisdom about tires I have learned. First, always use a tire pressure monitoring system for your trailer tires (my truck has them built in). Second, use Michelins. The Eddie Bauer comes equipped with 16' "Q" rated Michelins, which is, in my opinion, optimal. Q rated trailer tires are designed for speeds up to 99 mph on a 120 degree day. Presuming you get the Michelins, consult the air pressure chart supplied by the company and do a cold inflation to the weight range you actually have on the tires.
Your tire failure was very probably due to a loss of pressure. The downside to a tire failure like the one you described is the overloading of the remaining tire on the same side. It is definitely possible to then lose the second tire, and that can be catastrophic.
09-05-2015, 01:42 PM
2006 19' Safari SE
laguna beach, ca
tire question from single mom with no idea what she's doing...
All four of my tires on my 2006 safari 19' airstream are flat. I'ts been sitting for 8 years in an RV lot for storage. Now I have to move it because the RV storage company is going out of business but all my tires are flat. Im looking for a cheap temp tire that i can replace the old ones with so i can tow it to a new storage lot. the size of the tires on it now are: PDHH MLOR 0203 SIZE ST 225/75R - how many lugs does it have? does anyone know? Can I put these tires on it?
2-Pack Trailer Wheel & Tire #420 ST205/75D15 205/75 D 15" LRC 5 Hole White Spoke - 5 lugs????
09-05-2015, 02:17 PM
2014 27' FB Classic
Cambridge
, New York
12 Volt Compressor
No expertise on tires whatsoever (which is why I read all of these tire posts), but I can share my experience with 12 volt compressors. I bought a Viair 300P after much shopping and comparing. Works like a charm. But I also bought a Jegs 7.5 gal stainless steel portable air tank, and then upgraded the tank by putting a shutoff and standard coupling. Also got a 6' Goodyear pneumatic hose/connectors, and a good Milton chuck with gauge.
One of the issues with a 12 volt compressor is they tend to have short power cords to hook to the battery, so bringing the compressor to the TT tires (or back TV tires, for that matter) is a no go. I also have a AirSafe hitch that needs pressurizing, as well. That's why the portable tank comes in handy. I just fill the tank up to 100#s and I can top off a couple of the tires per tank. It also comes in handy to fill from my big compressor to top off a car or lawn mower tire without hauling out the big unit and running a lot of hose.
Good news was that all of the above is made in USA (except Viair - I couldn't find a 12 volt compressor made in USA for under $500!). And everything has performed as planned so far...
Get some good tires and keep safe!
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
09-05-2015, 02:31 PM
Lower Alabama
, USA
Tire Autopsy "Root Cause"
Roger (Tireman9), thanks for your replies. I hoped you would have the time to comment.
For those who are interested, here are couple of good links on the subject of tire failures. (From Roger's blog by the way).
The first link has photos that are remarkably like the photos posted by the OP of his failed tire.
RV Tire Safety: A Tire Autopsy "Root Cause" Part 1
RV Tire Safety: A Tire Autopsy "Root Cause" Part 2
Alan
Air #64439
09-05-2015, 02:45 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Have the VIAIR 450P Automatic Function Portable Compressor to carry in the Mercedes when towing the 23D International. We modified the power cable to two pin plugs and have the mating receptacle in the space behind the refrigerator that is only a few inches from the 300 amp-hour battery.
